AF1 received and installed!!
Old Jul 10, 2005 | 11:17 PM
jasonkola's Avatar
I am not sure it is as differant as it looks in the pics. I think it might be the angle of the pics. if you look at the wires to the alternator they are in the same spot on the bend in the tube. I think jpdadeo's pic is more above and to the right, and a little closer up. I think changeing that angle changes the look. but the breather tube is definitely different.
Old Jul 10, 2005 | 11:20 PM
jpdadeo's Avatar
It’s obviously a different tube configuration but why put the breather hose on the bottom
Old Jul 10, 2005 | 11:27 PM
jpdadeo's Avatar
Here's a pic that's a straight away shot
Old Jul 10, 2005 | 11:39 PM
jasonkola's Avatar
your right its definitely a differant tube design. I am not sure if they just reversed it or lengthened it or both. the only reason I can think of them putting the breather tube is for appearance purposes. I think I will email troyer and see if there was a design change and if so if it changed the performance numbers. it is possable I got the wrong intake.
Old Jul 11, 2005 | 12:00 AM
kd4crs's Avatar
Maybe it was messing up the MAF function or fouling it with crankcase vapors???
Old Jul 11, 2005 | 12:08 AM
jasonkola's Avatar
it will be interesting to see if new ones comming out look the same as mine or jpdadeo's. if they look like mine it means there was a design change. if not it probably means I got the wrong tube. I did email troyer to see if they new anything about it. I guess I will know tomorrow.
Old Jul 11, 2005 | 12:18 AM
4X4CrewDude's Avatar
Maybe a change was made for the ones giving a CEL? Perhaps many more than the ones here were experiencing the problem so they made a change in the tube??
That would be my only guess.
Old Jul 11, 2005 | 05:37 AM
wattman1's Avatar
jason,
I just got my AF1 (2004 F150, FX4, 5.4L) last week (through Troyer's, but drop-shipped from AF1 directly) and mine looks exactly like jpdadeo's. If you just received your AF1, and there was a design change, then I got the old version. Otherwise, your's looks different - both the curvature of the tube and the location of the breather (which, honestly I can't even see in the photos of your setup).
Something is weird, but I am sure Troyer will get it figured out (and corrected, if need be) for you.
That AF1 DOES sound good with the Magnaflow exhaust.
Old Jul 11, 2005 | 08:56 AM
jpdadeo's Avatar
I’ve been browsing the Ford intake kits pics on Troyer’s web page and there is nothing with a similar configuration to the one you got jasonkola, so I don’t think it’s the wrong one they sent you. I’m leaning toward the “second generation” thing myself.
You know you give Airforce One a call directly and get the skinny straight from the horses mouth. They’re on California time.
The toll free phone number is 1-888-788-4648
I called them and spoke to Evert,the tech guy, when I first got my AF1; I had a couple of questions about the install.
Old Jul 11, 2005 | 04:41 PM
Ragged05FX4's Avatar
Mine also comes out like the pic on the top, the tube starts a sharp angle towards the corner of the engine bay directly coming out of the top of the intake.
Old Jul 11, 2005 | 07:15 PM
jasonkola's Avatar
I just got home from work and got my emails. troyer says that there was a recent design change to address the lean condition alot of people have been haveing. so it was a design change and I must have got one of the first ones out. I just hope I am not getting less a horsepower increase than those of you with the old style. this new model should be tested for acurate HP gain claims.
Old Jul 11, 2005 | 08:28 PM
Crash_edwards's Avatar
They are different, and AF1 has changed the tube to take care of the dreaded CEL issues. The new tube is supposed to fix the problem. I have an early 9/03 build date. Mine is supposed to be shipped this week to correct the problem that I have had with the CEL.
Old Jul 11, 2005 | 11:44 PM
HotLap's Avatar
Plus the AF1 logo would be reading backwards as well....my breather tube was on the side and all fit ver well. There is a difference in those two pic though.....did the tube line up OK in the AF1 "Airbox" OK with both configurations? Strange indeed!!
Old Jul 13, 2005 | 07:13 AM
Speedway's Avatar
I just received the newer designed AF 1 as well, it looks like Jasonkola's model. No cel's thrown with about twenty five miles driven....with that seat of your pants difference.
Old Jul 13, 2005 | 07:40 AM
jpdadeo's Avatar
The BIG question now is going to be the hp & torque gains; NEW vers OLD tube design
