Has anyone used Pro Clip ?
Old Jun 20, 2005 | 03:44 PM
Bigmoss's Avatar
Has anyone used a ProClip in there Screw to install a Sat Radio, I saw the clip here used somewhere else and order one for my truck, from the looks of the pics the plate attachted to the clip was pushed on after but it os not, it comes as one full piece and it looked like you have to screw through the bracket into the plate which will not be easy.
I do not really want to use 2 way tape because with a Black truck and Black interior it seperates with the heat and falls apart.
This is a pic of the bracket, what I am looking for is suggestions on how to mount the radio cradle to it without having to use 2 way tape ?
Any suggestions ?
Pro Clip
Old Jun 20, 2005 | 03:49 PM
Crstfr's Avatar
hey big moss.. check out my gallery, you can see how i mounted my sirius.. I looked online and found alot of differnet ways to mount this.. but to me.. i like my idea the best.. one clips on the right side of your stereo blockin the passenger vent, which i didnt like, they also said some were puttin them on the center hump..wtf?? i didnt get that spot~.. oh well. hope this helps..
i just added the doc pic, i didnt have it in there.. its hard to see but its screwed down .and lays flush on the front.. in that pic it looks like the black liner is warped, but its not.. i promise~.. it was a nice install and its really easy to see, read and change channels without takin your eyes off the road~
chris
Old Jun 20, 2005 | 03:54 PM
Bigmoss's Avatar
Hey Chris thanks for the reply, I had a look and that is a nice mount, if I owned my truck thats what I would do, but I leased it and work with it. I have to park in some bad areas and that is too noticeable and would probably get stolen.
I have the proclip already in hand now and I know a few people here used it did a search but did not come up with anything. Just do not like the 2 way tape as it always comes apart and falls off with the heat issue.
BM
Old Jun 20, 2005 | 04:49 PM
Rockpick's Avatar
Moderator &
The linky didn't work for me...
I'm utilizing a mount from Pro Mount for my MyFi XM unit... I really like it and it's custom for the F-150. Here are a few pics:
http://www.pro-fit-intl.com/
Also, there's a BOATLOAD of info in this thread.
Old Jun 20, 2005 | 04:53 PM
les017's Avatar
Rock,
That actually looks like a nice clip!! I may need to look further into this.
but, on a side note, for god SAKES man...turn your dash vents in the same direction before taking a picture. Don't sully your rep by getting lazy now
Old Jun 20, 2005 | 06:02 PM
SafetyDaveG's Avatar
I have two. I got the one for the left side of the console for my XM radio and the one for the left side of the steering wheel for my cell phone.
I disassembled the XM car mount and mounted it right to the Proclip. I did not use the double sided tape, the mount is very tight. (I may change my mind when it heats up here in Atlanta.)
The positioning is just within arm's reach and I don't have to shift my eyes too far off the road.
I have had them in for about three weeks & so far, so good.
Dave
Old Jun 20, 2005 | 06:46 PM
Bigmoss's Avatar
Dave could you explain or do you have a pick of how you mounted the car cradle to the pro clip, you can email me if you wish bigmoss@rogers.com
Thanks a bunch !
BM
Old Jun 20, 2005 | 09:08 PM
Rockpick's Avatar
Moderator &
LOL!
Old Jun 20, 2005 | 10:09 PM
DAThomas9's Avatar
Check out all sorts of mounts at www.myradiostore.com
I used the same mount as Rockpick, and recommend it highly. Literally one existing screw to mount it.
Old Jun 20, 2005 | 10:20 PM
asinatra's Avatar
I have the same thing but do not like how the unit "pushes" the radio bezel to the left making the gaps on each side of the radio uneven.
Old Jun 20, 2005 | 11:47 PM
les017's Avatar
Originally Posted by RockPick
LOL!
Well?
Old Jun 20, 2005 | 11:59 PM
DAThomas9's Avatar
Yea, the gap on the right side is about a 32nd more than the left side, and unless you're specifically looking for it, you'll never know. The fact the bezel protrudes about 1/8" from the dash helps hide the difference.
I'll take a non-adhesive, completely removable installation with no noticeable changes over an adhesive or bulky one any day.
To each his own. Whatever you do, get satellite radio.
Old Jun 21, 2005 | 12:02 AM
DAThomas9's Avatar
Well?
No kidding, RP. I AM disappointed.
Old Jun 21, 2005 | 12:10 AM
mwheue's Avatar
Bet there's a print on his shiny shift **** too!
Old Jun 21, 2005 | 12:11 AM
wattman1's Avatar
I got the same one as RP and DAThomas from myradiostore.com I mounted mine to the left of the ashtray (attaches with 1 screw) as I wanted the MyFi closer to me and not so high up (on the right upper side of radio) and so far away. I can rest my hand on the shifter and adjust the MyFi.
I had to bend the mount just a little to get it to clear the mounts for the tabs on the bezel.
Get the Vehicle Specific Mount for the 04 -05 F150. The Universal mount from Bracketron (~$30 at Best Buy) would require some fabbing and I couldn't see an easy way to do it. Had to return that one...
The 04 VSM/Pro Fit does push the bezel off center a little, but not much.
Got camera problems (still), or I would take a picture. $@%@@!! camera....
