Gear info needed quickly!
Old May 4, 2005 | 09:26 PM
BlkButy's Avatar
I need to know what the costs are to upgrade to 4.56 Gears and what brand is best!
Help - The wife may be feeling generous now that I have caused trauma over this BlkButy - LOL!
Old May 4, 2005 | 09:39 PM
Quintin's Avatar
Setup costs vary depending on who's doing the job. I'd say 6-8 hours worth of labor as a rough guestimate.
Which brand? For what axle? I've always liked FRPP gears for Ford axles; Richmond is good, just stick with any reputable brand name and get someone who knows what they're doing to set it up, and you'll be fine as frog's hair.
Old May 5, 2005 | 12:08 AM
canyonslicker's Avatar
I was quoted about $1500 for front and rears Genuine gear 4.56s Parts and labor, they wanted to have 2 days. They said 1 day is not enough time.
When I do mine, I am going to have Energy Suspension polyurethane bushings installed at the same time. I can't really see them charging very much, if anything extra for labor. They will have the components out anyway.
The Energy Suspension polyurethane bushing kits for the '05 are suppose to be out within the next 2 weeks. I am not sure if they will have the graphite impregnated available in the same time frame.
Good Luck
Old May 5, 2005 | 12:22 AM
Screw2004's Avatar
Had my gears done 1500 miles ago 4.56 front and rear it took 3 hours and cost $1100,00
Screw2004
Old May 5, 2005 | 12:29 AM
Screw2004
Anywhere near Orange county???
Old May 5, 2005 | 12:33 AM
Sgt.Pepper's Avatar
Cost will be more in Kansas TOTO!
Old May 5, 2005 | 12:39 AM
Sal FX4's Avatar
I had Yukon gears installed. I checked around and decided on the guys who guaranteed me no gear noise. Also, the mechanic (Ryan) has been doing ring and pinions since 1992 so i figured he knew a little bit about it. They charged me $1700 total. I called a couple of places and they said ALL gears make noise (Which I know is not true) But i found 2 shops (that were charging the same) who knew what they were doing and guaranteed their work. Remember, gears installed properly will not make any noise. You might want to check with some local race shops who specialize in rear ends since drag cars mostly always change ring and pinions for quicker e.t.'s
Good luck.
Old May 5, 2005 | 05:20 AM
Screw2004's Avatar
Sun Valley Ram Jet gears great guys they also build gears for stock cars and trucks
Old May 5, 2005 | 05:35 AM
Screw2004's Avatar
Phone#(818) 768-3824
Old May 5, 2005 | 08:13 AM
bluehosefb90's Avatar
hey black, i had a thread about some 4.56 gears the other day where i called to various places to order gears and replacement kits....the lowest price i found was from reider racing...199 for the gears and 149 for the kit. This was also for a two wheel drive so double the cost for the gears. Whatever the cost of installation is should be much less than the 1500-1700 dollars quoted here. also, the gears are precision gears...as the companys work in conjunction. :santa: hope this helps
Old May 5, 2005 | 08:33 AM
SuperCrew02's Avatar
Mine run $1500 installed from and rear. Like someone said previously, any of the large manufacturers should be good. I used Superior Gear and im happy with them. I have heard good things about Richmond and Yukon. Supposeldy Motive is made by Richmond.
Old May 5, 2005 | 08:39 AM
BlkButy's Avatar
THX for all the replies!
I think Yukon is who I am going to go with based on my research!
I was quoted $400 for the gears and roughly $500 for labor!
Old May 5, 2005 | 09:02 AM
Sal FX4's Avatar
Blk, Keep us posted!!! Also, I need mpg figures from you since you drive yours everyday (I am guessing).
THanks!!
Old May 5, 2005 | 09:48 AM
YOMAN's Avatar
WAIT....
Why dont you throw Detriot true trac in front and rear along with upgrade gears ??
if i have money i would do that and get rid of POS factory limit slip.
Detriot true trac has NO CLUTCH PACk, no wear parts!
YOMAN!
Old May 5, 2005 | 10:51 AM
digipax's Avatar
I paid $1200 for parts for front & rear gears, front Eaton electric locker 31 slpine stock is 28 spline, ( had new front axles built out of 300M $400 for those ) solid spacers not a crush sleeve on pinions and new seals. Did the labor myself. Put 12000+ miles on them thus far.
