CAUTION 6" spacer lift.
Old May 2, 2005 | 02:05 PM
04fx4yfz's Avatar
here are some pictures of what happened to my 6" pro comp lift. i believe that the stock coilover bottomed out causing the failure or the procomp spacer bent and gave way causing the coilover assembly to curve
here you can see the curve in the coilvoer assembly it should be straight, it is resting on the side of the coil bucket
this is where the coilvoer spacer pushed up through the mount
here you can see the bend and wher the upper control arm hits the spacer
Old May 2, 2005 | 02:06 PM
04fx4yfz's Avatar
here is where the procomp spacer bent at the welds on the mount.
here is the solution to the problem
Old May 2, 2005 | 02:08 PM
04fx4yfz's Avatar
i chose the fabtech coilovers because they are made by sway a way. who also makes a big portion of the coilovers that are used in baja race trucks.
they are amazing off road, and are extremly stable on the road. i love them, these are the best thing that i have done to my truk yet
Old May 2, 2005 | 02:32 PM
Sal FX4's Avatar
Holy Crap!!!!
How's the ride now with the Fabtechs??
Old May 2, 2005 | 02:34 PM
Sal FX4's Avatar
Oh yea, and are you gonna get that upper ball joint replaced anytime soon?
Old May 2, 2005 | 02:37 PM
04fx4yfz's Avatar
the ride is amazing off road, you never seem to loose control no matter how hard you push it. and i push it very hard.
I'm waiting for camburg to come out with there upper control arm and replace the whole thing, it should be similar to total chaos's arm
also my upper control arm is no where near my coilover now as it was rubbing with my daystar on there even with it cranked up 2"s
Old May 2, 2005 | 02:45 PM
Sal FX4's Avatar
I know what ya mean on the rubbing part. How much did the coilovers set you back and any idea how much the control arms are gonna cost?? Thanks!
Old May 2, 2005 | 02:57 PM
sacramentojoe's Avatar
Well I guess that answers my question wether or not I should go for the Coil overs or get some upgraded shocks.
Coil overs it is.
Old May 2, 2005 | 03:12 PM
04fx4yfz's Avatar
they were like 850 at 4 wheel parts wholesale. they had them in stock here in arizona. they also had the procomps, but the procomps are made by procomp, so the fabtechs that are made by sway-a-way are much better coilover. these shocks also have a place to add the resiviour the the coil over which i will be doing soon
i'm guessing that the upper control arm should be reasonably comparable to the price of the tundra arm, it being basically the same concept, like 500. i think i remember total chaos (chaosfab.com) asking like 700 for the upper arm and the upper shock mount and the reseviour mount
Old May 2, 2005 | 05:26 PM
NukePooch's Avatar
Yet another reason I'll never again spend my money (not that I have any right now) on Pro-Crap stuff...been burned too many times. It's cheaper for a reason. Much thanks for the heads up...
Old May 2, 2005 | 05:54 PM
StAugTonka's Avatar
Hey 04fx4yfz, I'm runn'n the Fabtech w/ Dirt Logics. Have you noticed any popping sounds coming from the front while being in 2wd while turning the wheel at slow speeds even though you have the pro comp lift.
Mines just started doing it the last week and a half, I'm not sure if it has to do w/ the lift now settling in. Been in about a month now. Also, just cranked down the drivers side retaining ring, appears it backed itself off. I noticed how far down you have your ring cranked down, does yer truck sit level.
Thanks, Chris
Can I bug you w/ some more ?'s.
Old May 2, 2005 | 08:08 PM
BlkButy's Avatar
Makes me wonder to about Pro Comp!
They still have not responded to my question concerning the Tie-Rod rubbing against the Coilover.
I heard the Fabtech Coilovers ROCK. I think I may be upgrading that 1st!!!!!
Is it me or are the Fabtech Coilovers smaller around?
Old May 2, 2005 | 08:14 PM
StAugTonka's Avatar
Yep, smaller in dia. than the stck coils.
wandell's Avatar
What were you doing when the coilover bent? You must be really hardcore!
Old May 2, 2005 | 08:27 PM
BlkButy's Avatar
I may need to upgrade that 1st and spend my money wisely!
