Red LEDs in Guages
Old Apr 30, 2005 | 10:07 PM
GotBeer's Avatar
Red LEDs in Gauges
Has anybody switched these out. The ones in the FX4 that light up the middle 4 gauges. I want to use some gauges from dakota digital that go where the ash tray is, but they only come in blue. Wondering if it is possible to change the color of those in the dash to match.
Old May 1, 2005 | 03:45 AM
asinatra's Avatar
i believe steeda (i think) has a 3 gauge CF peice that replaces the ashtry for the flow-thru consoles
just FYI
Old May 1, 2005 | 09:40 AM
Sal FX4's Avatar
just FYI
Found it!
http://www.steedatruck.com/F-150/
Under Accessories.
F-150
ADD TO CART
Description Price
067-450101 Gauge Pod - Carbon Fiber - Fits 04 - 05 $79.00
067-450100 Gauge Pod - Unfinished / Paintable - Fits 04 - 05 $50.00
I guess I'll be adding this to my list but which gauges??
...Does it ever end?? Don't answer.
Old May 1, 2005 | 10:30 AM
ThumperMX113's Avatar
Now thats pretty cool but they need to come out with a wood grain edition!
Old May 1, 2005 | 11:40 AM
takotruckin's Avatar
it would be really cool if it matched the carbon fiber better. as for gauges go with oil press. water temp, and egt if you have a tuner
Old May 1, 2005 | 12:37 PM
GotBeer's Avatar
That is what I plan on doing. The only problem is the guages I want only come in blue lighting. So I want to switch the ones in the dashboard to blue so it matches. Has anybody done this?
As for the gauges dakota digital makes a tire pressure, tranny temp., and 1 more im not sure yet.
Old May 1, 2005 | 02:23 PM
asinatra's Avatar
There is 6 bulbs in the back of cluster, you can try changing them to blue, the thing with this is that the actual gauges have a green flim on the back. green + blue =
Old May 1, 2005 | 10:47 PM
dlewis1340's Avatar
Anyone know what model number bulbs are in the back of cluster?
Old May 1, 2005 | 11:05 PM
SteveVFX4's Avatar
As for the 3 little gauges, you want them in red? Because I believe Cyberdyne makes digital gauges that come in red. I think you can buy them all over the internet. They may or may not have something you're looking for, but here is their homepage:
http://www.cyberdynegauges.net/
Old May 2, 2005 | 02:50 PM
GotBeer's Avatar
I do not want to change to color of all the guages. If you have an FX4 you will notice (when the lights are on) that the trim ring of the middle 4 gauges is lit up in red. Just the trim ring. That is what I am wanting to change.
