Troyer Performance -- Air Force One is NOW SHIPPING!
Old May 21, 2005 | 05:11 PM
  #136
jpdadeo's Avatar
RP, looking at your pic, it doesn’t appear you have the filter out toward the fender far enough. That’s how I had mine at first, but after reviewing the instructions (picture) I moved mine out farther.
my first try
after I moved it out
I don't guess it makes that much difference either way
Old May 21, 2005 | 06:08 PM
  #137
Rockpick's Avatar
Moderator &
I don't have enough length to go out any farther.... (the story of my life; lack of length).
Old May 21, 2005 | 06:38 PM
  #138
tycreek's Avatar
It does sound like the old 4 barrels opening up of yesteryear! ... and SOTP says it works! ... Can’t wait to try a performance tune! Here's as it turned out ... it's right in-between the above pics.
Old May 21, 2005 | 07:29 PM
  #139
jpdadeo's Avatar
The end of my filter is 2 ¾” from the inner fender now and it has approximately 1” more it could move and still be clamped solidly
Old May 21, 2005 | 10:29 PM
  #140
Rockpick's Avatar
Moderator &
Interesting...
Are you measuring from the lip of the fender (right on the inside nearest the engine compartment) or the actually tip of the fender?
Old May 21, 2005 | 11:40 PM
  #141
JerseyGeorge's Avatar
Rock, Great right-up! My next mod!
Old May 22, 2005 | 12:48 AM
  #142
jaguar63's Avatar
I installed mine this morning. No problems except one of the hose clamps that holds the elbow on at the throttle body was too small. I had to stop and make a trip to Home Depot for a 4-5" clamp. Followed the directions and took her out. What a difference! A real seat-of-the pants feel. Also I agree with the above, sounds like the 4 barrels opening up. Real neat sound and feel like someone pulled the cork out of the tailpipe! I too went through the filter placement deal. I now have it extended out more towards the fender well, with the hose clamp inside the box. Looks good. I also replaced the isolator bolts (nylon ones) with stainless steel. One of the nylon ones broke off during shipping, so I figure what the heck, might as well use stainless, it matches the airbox material and definitely won't break.
Old May 22, 2005 | 11:58 AM
  #143
jpdadeo's Avatar
Interesting...
I’m taking that measurement from the lip of the hole where the stock tube used to plug into.
That’s the closest part of the inner fender to the Power Stack filter.
There’s approximately 7” from that hole to the outside fender.
I’ve been thinking about cutting off the portion of the OEM tube, that goes through the inner fenders
cold air hole, and plugging it back in. It looks like it would direct more cold air down the throat of the
Power Stack filter, seeing how the end takes in air too. What do you think?
