Keyless entry?
You can change the code numbers to make it easyer to remember,but the factory code stays the same.You may need to get a new unit installed.I added the second code on mine but never use it,for after installing my FORD Gold system it gos off if you press on the key pad now.The way they break into vels now days the key pad is nothing to worry about if they want to get in they will.
we don't get a lot of requests for it but i think you can erase the key code using our computer diag system and set it to you what you want, but i can't say for 100% u can erase the factory code. i would phone your dealer and ask.
wildman they have the unlock sense wire wired wrong or the programing worng because i install our systems on a daily basis and u can use your key pad to enter the truck and it will disarm the alarm system, it does on my truck and every truck i have installed a gold on.
Mac.
Mac.
