check this out (glad I got an 04)
Old Jan 17, 2005 | 07:00 PM
Scubaman's Avatar
http://www.bridger.us/2002/12/16/Cra...operVsFordF150
Old Jan 17, 2005 | 07:57 PM
anaheim's Avatar
Me too...(see gallery)
I should be getting my truck back end of the month...
Old Jan 17, 2005 | 09:24 PM
Bancho's Avatar
Interesting I guess, but to some extent it is all about inertia. Heavier vehicles are less likely to do well in that particular test. The object the vehicles were crashed against was the "immovable object" type. So in the end, if you plan on crashing into a bridge abuttment, you'll fare less well than the guy in the Mini .
Old Jan 17, 2005 | 09:26 PM
kbldawg's Avatar
That just means you can by a mini and crash into anything you want, because it weighs 600lbs.
I'd like to see what happens when an F-150 hits a mini!! hahaha Now lets see those pics!!!!
Old Jan 17, 2005 | 09:38 PM
minus_13's Avatar
Originally posted by CrAz3D
Wait, isn't it a bad thing that the mini has a better crash rating than the F150?
Um... that's an 02 or 03 F150 in the picture... :o
Old Jan 17, 2005 | 09:45 PM
dzervit's Avatar
The article was from 12/02 and been posted a zillion times..
Old Jan 17, 2005 | 09:48 PM
Buck Henry's Avatar
The crash worthiness of the 97-03 version of the F-150 was about the only thing bad about the previous version of our truck. Ford did a great job in improving both head on and off set crash test ratings with the 04 redesign.
Old Jan 17, 2005 | 11:31 PM
anaheim's Avatar
Now its been posted a zillion and one times....
Old Jan 17, 2005 | 11:45 PM
lees99f150's Avatar
Old Jan 17, 2005 | 11:50 PM
apo143's Avatar
OH YEAH, I love this forum...
Old Jan 17, 2005 | 11:59 PM
snobanker's Avatar
I was going to point out that it was an '02 F150 also, but I won't since you guys already did and I don't wanna be a repeat
Old Jan 18, 2005 | 12:12 AM
Corpsie's Avatar
Originally posted by Bancho
Interesting I guess, but to some extent it is all about inertia. Heavier vehicles are less likely to do well in that particular test. The object the vehicles were crashed against was the "immovable object" type. So in the end, if you plan on crashing into a bridge abuttment, you'll fare less well than the guy in the Mini.
Actually it's probably a deformable aluminum barrier and the overall effect is equivalent to 2 F150's hitting each other offset.
The test is quite relevant.
Old Jan 18, 2005 | 02:34 AM
kamikaze2b's Avatar
The 2004/05 F-150's have had top scores from the insurance institute.
Old Jan 18, 2005 | 08:06 AM
Bancho's Avatar
I went and read some of the links again and it you are right. There was one point that indicates I was partially right too though:
IMPORTANT: Frontal crash test ratings can only be compared among vehicles of similar weights. Side impact crash test ratings can be compared across vehicle type and weight categories.
So comparing the Mini to the F-150 is not entirely accurate but did make their article more colorful.
Old Jan 18, 2005 | 08:37 AM
jpdadeo's Avatar
There’s gota be a little BS involved with this comparison. Where’s the front door of the mini? The photo of the mini is at a right angle where as the F150’s pic is at such an angel to maximize the visual effect to look the worst but in all fairness, I must say the mini still looks drivable with a little tug on the front fender to clear the tire.
