Help with PAINT on new Tonneau cover - Swirl Removal/Prevention Questions
Old Jan 15, 2005 | 10:10 PM
bamorris2's Avatar
Unhappy Help with PAINT on new Tonneau cover
About 2 weeks ago I got a new Sunglid SL. It's been raining cats & dogs for the last week, so today was the 1st time I've been able to wash it (and the truck). After washing & drying, the tonneau cover now has spider webs (swirl marks) ALL OVER IT! What gives??? I used a very high quality wash mit & shampoo. And no, I don't think they were there before I washed it.
1. Why all the swirl marks?
2. How do I get rid of them NOW? Will a good coat of wax do it?
Please offer your suggestion, and TIA.
PS - I know I probably should have posted this in one of the "Care" forums, but I thought I'd try this first since it gets alot more hits.
Old Jan 15, 2005 | 10:18 PM
Rockpick's Avatar
Moderator &
Re: Help with PAINT on new Tonneau cover
You're right. It should be up in GENERAL CARE AND DETAILING as that's where the majority of us who deal with this type of thing dwell.
But, today's your lucky day. I'm going to let it live here for a while before it's moved.
The swirls that you're experiencing were either introduced at the factory as part of the process (an improper use of a rotary buffer most likely) or, by the dealership from which you bought it from during their prep (again, with a power hand tool used improperly or with an improper compound).
So, you have swirls... let's get them out.
Let me ask you a few questions before we progress.
1. Do you have any experience with a power 'rotary style' machine? This includes, but is not limited to, an orbital buffer, rotary buffer, or dual-action polisher?
2. Are you familar with swirl remover compounds and/or other compounds?
3. Do you understand what the swirls actually are? I don't ask this to be a smart-****, I'm just trying to guage the level of my response.
4. Are you comfortable doing this by hand? It may require SEVERAL applications and SEVERAL hours to take care of them.
5. Have you ever utilized a professional detailer in your area? Do you know of any? Do you trust someone to advise you on one?
Hmm, I think that's it for now. Be prepared, you're going to get a VERY winded response on swirl mark removal and prevention. It'll be a short-course.
RP
Old Jan 16, 2005 | 01:20 PM
bamorris2's Avatar
Re: Re: Help with PAINT on new Tonneau cover
Yes, I have used an orbital before with good results.
Not really.
It is my understanding that swirl marks are actually minute cuts in the paint (right???)
I would rather do it by hand.
If it comes down to it, I do know of a detailer that I could turn to. But I would much rather do it myself.
RP - thanks for letting this post hand around in this forum for a while
Old Jan 16, 2005 | 03:54 PM
Rockpick's Avatar
Moderator &
Stay tuned... I'll have you a response shortly. Football is on right now... sorry.
RP
Old Jan 16, 2005 | 11:48 PM
Rockpick's Avatar
Moderator &
Alrighty... Settle in.
This post takes up TWO INDIVIDUAL POSTS as it was too long by over 3 thousand characters…
Like I mentioned in my first response, the swirls that you're seeing are probably caused by the improper use of a machine applied product somewhere either in the manufacturing of the lid or at the dealership. Either way, what you're seeing is caused by millions of tiny scratches in the paint.
A swirl mark is, just that; a scratch. You see them in a 'swirly pattern' because of light reflections and such.
The good news is that you can remove them pending the lid that you have has a modern paint finish and has been topped with a clear coat material. To date, I've yet to see a 'modern' lid not be topped with a 'modern' paint technology however; I'm sure they exist.
I'm going to assume that your paint is modern for the sake of this discussion. It's up to you to determine if you have a clear coat on the lid or if it's a single stage paint. The work that you do with my advice is your work. Not mine. Just as a disclaimer; I can't be held responsible for anyone's work but my own. Use my advice at your own risk. Now, that's out of the way.
Here's how I'd attack it BY HAND (since you mentioned that you wanted to do it by hand -- which will be considerably more difficult and time consuming).
1. Work out for three weeks prior to application... your arms are going to get very sore. LOL! JK! Seriously, step one would be to obtain the products and such that you're going to need to make this happen. For starters, I'd get a 6-pack of terry cloth wax applicators, a few decent microfiber towels, a clay kit of some sort, and a bottle of Meguiar's Swirl Mark Remover 2.0 (this product is commonly called #9). You'll be able to find all of the above at your local Pep Boys or Auto Zone. Also, your local Paint and Body Supply House should carry something that is equivalent in either the 3M line or Meguiar's.
#9 Swirl Remover 2.0
Quik Clay System
2. Prepare the surface. Wash and dry the paint with your favorite car wash solution properly mixed and use a 100% cotton terry (ultra-soft) or waffle-weave microfiber towel to dry. Now, feel the paint with your bare hand. Does it feel rough to the touch? Probably so. I've yet to see a factory finish that didn't need some type of preparation outside of swirl removal. This is where the clay kit that you purchased is going to be used. To use this product, mist the spray lubricant on to the lid. Follow with the clay. The clay should be moved back and forth within the area that you sprayed the lubricant. Work small sections at a time.
That rough feel that you've experienced is caused by surficial contamination. This can consist of tar, sap, industrial fallout, paint over spray, and about a billion other things. It's critical to remove these imperfections as you're going to be attempting to remove problems that may lie beneath the surficial stuff. In short, I don't want you to use those arms that you've worked out with over the past three weeks to grind in a tiny fleck of rail dust that becomes dislodged and introduce bigger and harder to solve problems.
THE KEY TO A KILLER SHINE THAT SNAPS HEADS IS SURFACE PREPARATION!
Remember that...
Follow the directions on the Clay kit to the 'T'. It's VERY easy to use. One golden rule with clay, if you drop it, it's trash. No exceptions. One grain of sand embedded in the clay and then drug across your paint can and will spell disaster. I commonly recommend cutting the clay bar into two equal pieces for just this reason. When you drop it (and you will one of these days -- I dropped two large bars last year), it's not as painful to trash it when you have a back up. Clay isn't cheap either.
3. Feel the paint again. Feel that glass-like feel now? That's how a modern finish should feel! Congrats, you've removed the surficial contamination. Obviously, we've yet to get to the swirls but, you've made your next task easier and safer.
If the paint still has some rough feel to it. Investigate it VERY closely. Get your nose down to the paint and look at what's causing it to feel rough. Can you fleck it off with a fingernail? If so, get busy... lol... just kidding. Use the clay a bit more. It should remove it. I've only run across a few instances while detailing where I couldn't get the clay to remove what was on the surface. If this occurs, it's not the end of the world, just let me know and we can kick up the aggressive nature three notches.
3. Oh yeah, we've already done this one...
4. Time to get busy with the swirls. I might recommend washing the lid area that you've clayed again to remove any residue that may be left behind. This isn't a critical washing but, it's probably safe to do it. Pay VERY special attention to your drying technique. LET THE TOWEL DO THE WORK. Don't press down and make sure you're keeping your towels off of the ground. Remember, just about anything can introduce scratching to your paint. Just think what a towel is doing while it's on the ground or, even worse, on the concrete. KEEP YOUR MATERIALS CLEAN AND STORE THEM WELL (a free tip there).
5. Swirl mark removal. I know I said we'd start in #4 but, well, I forgot to lecture about keeping your materials clean...
Take your terry applicators and the #9 swirl remover that you've purchased. Apply a nickle sized portion of #9 onto the applicator. Take the applicator and work a very small area. This isn't wax! This is an abrasive polish that will remove some of the clear coating on the lid so that you're able to remove the scratches. This is safe in the method that you're applying and there's no need to worry about going through the clear coat. This product isn't nearly aggressive to achieve that and will break down long before you can get to that point because it contains diminishing abrasives.
Now I used a term in that last paragraph that may be confusing; work. When I say 'work' the product, I mean to continually rub it in the same immediate area. Like I said, this isn't a wax and thus, you don't just apply it and wipe it off. You're achieving mechanical abrasion to remove the swirls. Again, don't worry; with #9, you're using a VERY safe product.
Personally, I don't like to let this product haze but, I like to work it until it is almost dry. I stress the word ALMOST. Do not ever work any product while it's dry. This can and will reintroduce swirling.
So, wipe it off. Examine your work. See any difference? You should if you worked the product correctly and for the right duration. It's okay to use a little bit of downward force while doing this but, I don't want you to strain. I don't say that to be a smart-**** again but, more so that you're protecting your paint. Nothing about this application should cause you to strain.
If you still have some swirls, and you probably will after one application, repeat. Repeat. And repeat again. This product is mildly abrasive and, not knowing what variety of swirls that you have on your lid, I don't want to recommend anything that's more aggressive. In short, it just might take a few tries to get it right.
6. Once you've removed all of the blemishes, get a couple coats of your favorite wax on your lid. Many of us like Meguiar's products like NEW NXT Generation Tech Wax Paste (also available in liquid form) or Meguiar's Cleaner/Wax or Medallion Premium Paint Protection but, I want you to use what you're comfortable with and what you trust. The key is to use it and use it often.
NOW, we've removed the gunk on the surface with the clay and have, hopefully, removed all of your swirls. Let's talk about how to prevent them now.
Swirls, as we mentioned earlier, are just microscopic scratches in the paint. We need to do anything that we can to prevent reintroduction of these scratches to the paint.
CONTINUED IN NEXT POST
Old Jan 16, 2005 | 11:49 PM
Rockpick's Avatar
Moderator &
Here are a few helpful hints to keep the truck swirl-less...
1. No auto washes; especially the ones with brushes. These spell absolute disaster. I don't mind the touch-less ones so much in the winter but, be aware, the chemicals used there WILL strip your wax. No exceptions. And the 'hot wax' that you spring for at the end is useless. Save your money.
2. Pay attention to your hand washings. Use clean buckets, clean wash mitts, clean everything. Don't toss your materials on the ground where they can pick up grit and sand. Further, change your wash-water a few times while you're washing a very dirty vehicle. It's cheap to do this and can save you oodles of headaches.
3. Use the two-bucket method. I use this exclusively on any vehicle I detail. This entails filling one bucket up with your choice of wash solutions properly diluted and another bucket with fresh water. The idea is to capture the 'goop' that you wash off of the vehicle in the fresh water so that it's not introduced to your soap bucket. I have changed the water in my rinse - fresh water bucket as many as 10 times while washing my truck. Even more recently, I changed the water 8 times while washing a Honda Civic -- yes, it was THAT dirty.
4. Pay attention to your mitts and sponges. Don't use the same sponge that you just washed your wheel well with on the paint. Reserve some of your older mitts for this task and segregate them from the wash water. Under no circumstances should this sponge and the one that you just used to wash your hood come in contact with each other. Think about the grit and sand that you pick up with your sponge or mitt. Make sure to get it off your mitt.
5. Technique, technique, technique. Some of us have black or other dark colored vehicles. As we all know, these are some of the prettiest cleaned up but, also the worst looking when they're swirled to hell and back. Let the sponge or mitt do the washing. You shouldn't have to 'scrub' any thing. Start at the top of the vehicle and work downwards.
6. Use common sense. If you feel like it'd benefit you to run by the 'wand-wash' and use the high-pressure water to remove some of your gunk, do it. It's cheap and works VERY well. Don't hesitate to dump buckets. Car wash shampoo and water are cheap. The time you spend to remove the swirls, probably, isn't. If it's muddy, spray it all off first. Pay special attention around your wheel wells. This is where the majority of the gunk is probably located. Also your front grille/bumper. The car in front of you on a wet day is peppering you with grit and sand. Some of it will stay there.
7. Don't cut corners.
8. Don't cut corners.
9. Don't cut corners.
10. Drying techniques. Anything that rubs across your paint can scratch it. If possible, use a leaf blower or something similar to blow your paint dry. I know it sounds stupid but, my neighbors have become immune to my activities at this point in time (it took about 2 years to achieve this though -- you'll still get weird looks). If the air option isn't an option, utilize the softest, highest-pile 100% cotton terry towels available. Even better, use a nice microfiber waffle-weave drying towel (like this - Water Magnet Drying Towel or this one.
Let the towel do the work. No downward pressure is necessary!! Again, pay very close attention to where your towels go. If they get into a wheel well, assume that they're covered in gunk and that they shouldn't go across your hood.
I could go on and on and on and on (more so than I already have) but, I think you get the picture. I hope that this has helped you (and a bunch of other folks) a bit. If you have any further questions, please don't hesitate to ask. I do this as a side profession and moderate another prominent auto detailing message board for Meguiar's Wax Company based out of Irvine, California. If I don't have the answer, I'm pretty sure that, with the depth of resources that I have available, I can find it. I'm not tooting my own horn here, just trying to extend a hand if you need it.
Even better... screw all of my directions and swing by on a weekend. I'll remove them cheap. Pre-warning though, I'm going to use the same techniques that I've spelled out for you... and a rotary.
Let me know if you need anything else!
RP
Old Jan 16, 2005 | 11:55 PM
Rockpick's Avatar
Moderator &
I'm going to copy this one up to GENERAL CARE AND DETAILING as well...
While the data is long and, somewhat, tiring, maybe some other folks can contribute to it and help it be a better post.
RP
Old Jan 17, 2005 | 12:33 AM
ke7065's Avatar
RP-Excellent post. I detailed for 20+ years, and you summed up this technique very, very well.
Brad-You'll probably see a lot of variation on product, but RP's techniques are right on. Clay work will make a world of difference. Many will use rotary (high speed) buffers, but I would have no problem using a good random orbital for this job you are going to tackle.
As far as drying, the towel vs. chamois is an age-old debate. Premium setup is a spot free rinse system at home. Otherwise, use a little bit of fabric softener with the towels when you wash them-our water is way too hard here. Those water blade things can work, but everything must be very very clean.
For us in SoCal, I am usually just fighting dust on my truck during the summer. Hit those DIY car washes with the spot free rinse. I rinse out the brush, wash my glass ONLY with the brush, then spot free the entire truck. As long as it is relatively clean, you can buy some time between washes (got 4 boys-time is much shorter for car maintenance!).
Since you are in SoCal, I would also recommend Pro brand products. They make a product call DuzAll that has the 'diminishing abrasives' that RP refers to. Lots of good waxes too. Another brand is One Grand out of Ventura. And of course, Meguiars make fantastic products too (will that keep me from banishment RP??? ).
Sorry to go a little OT. Good luck and let us know how it comes out.
Old Jan 17, 2005 | 12:38 AM
DAThomas9's Avatar
Wow. Can't ask for a better reply to a question. Nicely done, effort appreciated.
Couldn't help but notice the word "chamois" doesn't appear in the drying section. I assume that might be a dirty (pardon the probable pun) word?
Old Jan 17, 2005 | 05:27 AM
Rockpick's Avatar
Moderator &
Thanks ke7065... I appreciate the kind words. Pro products are definately pretty good. I've used several including the DuzAll. I've heard of One Grand... never have tried them though. They're more of a local bathtub blender right?
No one will get banished... Like I said near the end of that novel, the key is to find a product that you like and use it. Use it often even.
DAT... Chamois isn't a bad word in my vocabulary but, I've never found them to have enough 'nap' to them in the case that I were to capture a grain of sand or similar. In short, I want there to be enoough space for a grain of grit/sand to go so that I'm not dragging it across the painted surface over and over. Sure, any towel could do it but, my personal opinion is that something with some nap (a cotton terry or waffle weave) will provide some room for that sand grain to make the trip safely rather than with scratching...
RP
Old Jan 17, 2005 | 06:34 AM
ke7065's Avatar
RP-One Grand caters to the fire service primarily. I know they do have products for aircraft also, but most ordering is directly from them.
Out here, FD's really pride themselves in the look of their rigs-heck, you spend $300-800k of the taxpayers dollars, you better be taking really good care of their investment!
Speaking of catching a grain or two of dirt-I really am learning to not like the body gap btwn the front bumper and bumper trim. Man, no matter how much I flush that area I still seem to get some grit dripping down there onto the top of the bumper! Ugh...
Old Jan 17, 2005 | 12:43 PM
bamorris2's Avatar
RP - Wow! I never expected anyone give me such a great detailing guide. I really appreciate it...
So I guess this isn't something I'll be doing at my leisure when I get home from work tonight
Anyway, I've been thinking about getting a DA polisher. I guess now might be a good time. I looks like it will save me alot of time & energy.
Again, thanks for all of your help. It will probably have to wait until this weekend before I will have the time... I will post the results.
Old Jan 17, 2005 | 07:09 PM
Rockpick's Avatar
Moderator &
No problem bamorris. Hopefully this post will not only benefit you, but several others that have swirls as well.
You're right, a DA might be a good investment. I saw a few on ebay not too long ago that were the Meguiar's variety (same as a PC 7336 or 7424 but with a LIFETIME warranty). As I recall, they were going for the same price as a new 7424.
Take some before and after shot to show it off and be sure to choose your pad correctly for the DA.
RP
Old Jan 17, 2005 | 07:17 PM
Rockpick's Avatar
Moderator &
You and me both man. There and immediately beneath the tail lights. No matter how much of a stream I put on the body line there, it continues to drip grit.
Are there holes within the tail light mounting areas like there were on the 01s? If so, I'm going to have to get in there and do my patented duct tape job. LOL! That's one sure fire way to keep the crap out of there and it's totally out of sight and out of mind.
RP
Old Jan 17, 2005 | 08:47 PM
ke7065's Avatar
Yeah, that was the other one. I flushed around, behind those taillights and stuff just kept on coming. Let me know if the 200 MPH tape works!!
