xm radio volume
Old Jan 15, 2005 | 09:18 PM
Scubaman's Avatar
xm radio volume
I just had my xm installed (pioner) now I have to turn the volume up 10 notches higher than before is that normal?
Old Jan 15, 2005 | 10:17 PM
inbred's Avatar
yes, it's normal (in both my last 2 xm tuners at least). Not sure of your setup; mine was/is FM modulated. IF modulated, you can adjust the output level of the modulator. Still though, with my modulator turned all the way up, it is still not as loud as normal radio/cd is. Scares the heck out of me on the odd occasion I switch to CD and forget to turn the volume down...
Old Jan 15, 2005 | 10:19 PM
Rockpick's Avatar
Moderator &
It's the modulator. Unfortunately, it's the nature of the beast.
RP
Old Jan 15, 2005 | 11:15 PM
DAThomas9's Avatar
Most XM radios have a "line out" that can be adjusted to solve that problem. It is usually found in the menu area.
Old Jan 16, 2005 | 09:47 AM
Scubaman's Avatar
My tuner is a pioneer tuner with a kerk antenna. The hu is a pioneer xm ready radio. I think that means it is not modulated. I am a bit disapointed with the quality of the sound. It is better than fm but not as good as my cd player. A frind of mine owns a new mercedes and his serius sounds better than the cd player.
I have to look into the line out issue. I am bringing the truck back to the guy who installed it on monday just to check into it.
https://www.f150online.com/galleries...503-109922.jpg
https://www.f150online.com/galleries...503-111094.jpg
Old Jan 16, 2005 | 11:57 AM
DAThomas9's Avatar
The sound from a satellite radio signal is "near CD" quality. In ranking order based upon sound quality (best to worst), the options are:
Hard wired directly from the Line Out plug to the back of the radio.
Use of a cassette adaptor
FM Modulation
If your friend's satellite radio sounds better than his CD player, he must have a crappy CD player, because that is really not possible.
Is it the Commander that you have?
Old Jan 16, 2005 | 12:33 PM
BREWDUDE's Avatar
NAH...sounds like you have a problem with the HU. I have an Alpine thats XM ready. I just installed the tuner and XM antenna and it sounds great. Volume is fine and all. Take it back and have then fix it for you.
Old Jan 16, 2005 | 01:15 PM
Scubaman's Avatar
Ok I will bring it back monday. Thanks brewdude.
I have a pioneer tuner not the commander.
