High Beams and fogs same time
Old Jan 11, 2005 | 09:17 PM
jpdadeo's Avatar
OvalNuts you must have done it wrong, you need to re-check your work because HHIFX4 has a 04 FX4 and it worked for him.
Old Jan 11, 2005 | 09:25 PM
OvalNuts's Avatar
DO ALL TRUCKS HAVE THE SECOND R202 IN THE ENGINE BAY? WHEN I WAS DONE I HAD NO FOGS, THEN AFTER UNDOING WIRE AND STRAIGHTENING PIN 1 BACK PUT R202 BACK IN AND STILL NO FOGS. HAD TO GET NEW 202.
Old Jan 11, 2005 | 10:02 PM
jpdadeo's Avatar
If you straightened the pin back and it didn’t work maybe it broke inside when you bent it and it lost its ground altogether. Just a thought
Old Jan 12, 2005 | 10:14 PM
ZMANF150's Avatar
I am the one that originally posted this
It does work, and it works on all 2004 models with foglights. If you can't get it to work you are doing something wrong. I'm pretty sure its the same for 2005 models.
BTW, thats a relay, not a fuse.
zman
Old Jan 12, 2005 | 10:16 PM
OvalNuts's Avatar
WOOOOO HOOOOOO!!!!!!!!!!!
I DONE IT. it works. you were right i broke the relay during the mod. i got a new one. ran leads from each pin then to fuse box prior to bending pin 1 and it worked fine. then carefully went on with the normal mod IT WORKS FINE NOW YEEEEEEE HAAAAAAA.......THANKS ALL
Old Jan 15, 2005 | 07:56 PM
jbone108's Avatar
different way of doing it.
Heres how I did mine.
pulled the relay and soldered on a wire on the #1 lug as close to the top as I could.
I then took some electrical tape and cut it to cover the spade on conector making sure I could not see any metal
I then reinstalled the relay and hooked the other end wire to the grounding lug below the fuse box.
You may not have to use the electrical tape on the relay I just did that trying to stop a back feed.
took me less then 30 min and works fine.
Old Jan 15, 2005 | 08:12 PM
khendrix2374's Avatar
This is by FAR the best mod I have made to my truck so far. Plus, it was 100% free. Cant beat that.
Had to drive some back roads coming home couple of days ago, it looked like daylight infront of my truck.
Old Jan 15, 2005 | 08:49 PM
horseman's Avatar
I have done it on my 2005 and it works fine. Great Mod!! Thanks for the tip. Now I can see the dear on the side of the road further away.
Old Jan 15, 2005 | 09:23 PM
lees99f150's Avatar
In most states it is illegal to have fogs and high beams on at the same time. This is why the fogs go off when you flip the high beams on.
Old Jan 15, 2005 | 09:30 PM
We all know it's illegal. But,I dont run high beams in people's faces. So nobody should ever really know. Unless there is a cop on the side of the the road and he sees me. O well, its worth the risk to me.
If I got a ticket, I would just take it to court and say "Its impossible to run high beams and fogs at the same time" after I set it back to stock.
Old Jan 15, 2005 | 09:39 PM
jbone108's Avatar
most cops don't care. they have better thing to do like sleep and eat donuts
Old Jan 15, 2005 | 10:07 PM
jpdadeo's Avatar
Re: different way of doing it.
That sounds like a good idea. You’re right, I don’t think you even have to use the electric tape because it's only a ground to start with (nothing to back feed)
Old Jan 15, 2005 | 10:50 PM
Rockpick's Avatar
Moderator &
That or just know the judges... (Moore, Calvert, etc.. ). I know both personally.
RP
Old Jan 21, 2005 | 10:31 PM
jpdadeo's Avatar
Access the fuse box and find fuse R202 (top middle) Remove the fuse, bend pin 1 over to the side, and attach a wire lug and wire. Ground the wire, that's it
Now the high beams and fogs can be on at the same time
pin #1 is clearly marked
Old May 6, 2005 | 07:48 PM
Riken's Avatar
there's power to the female side of the pin, it has to be insulated or it will ground out.
