High Beams and fogs same time
I dont remember where I read how to do this, but it works...
To run the High beams and fog light s at same time is very easy.. only take a couple of wire lugs and a shot piece of wire. Go to passengers side floorboard and remove the kick panel to gain access to the fuse box. I had to use a flat head screwdriver to push in the little hole on the fuse box cover to remove it. Look at the fuse box cover and find fuse R202... I think it just says 202.. its in the top middle... then crawl down there and remove the fuse.. The fuse has 4 or 5 pins on it, all labled 1, 2, 3.... You need to bend pin 1 over and to the side of the fuse... You dont want pin 1 to plug back in to the hole... after pin one is bent over, attach a wire lug to it and a short piece of wire... then ground the wire to the frame somewhere... I found a small hole in a metal bar and grounded the wire to it. Thats it.. your done... now high beams and fogs can be run at the same time. I also had to trim a little piece of plastic out of the fuse box to allow clearance for the bent pin to slide in... P.S. I checked at the ford dealership to see how much the relay/fuse cost... $12.01 plus tax..... Useless info unless you break the pin. Sound confusing... but its really easy. Good Luck |
exxxcellennnt .... :thumbsup:
sweet...im doin it
this is a great and easy mod. i did this earlier today. took about a half hour. if you pull the whole kick panel off, not just the cover, there is a green ground bolt right there beneath the fuse panel. it already has ground wires running to it. i used that bolt to ground the relay. having the high beams and the fogs on really makes a difference. :thumbsup:
i just did this... works great!!!
That looks like a good mod for cheap. Got a question. Do the fog lamps still work as before (able to be turned on and off independently) but now they include the hi’s in the mix too?
yup!
Sweet! I ll do it...
Just a suggest..Maybe snap a pix so other will understand ( not to confusing) Thanks! YOMAN! |
A few pics would be great. Thanks for the post !
How about 01 supercrews
will this work on 01 screw
I will try to take a couple of pics tommoro.... maybe tonight
https://www.f150online.com/galleries....cfm?gnum=5192
Here is a pic of the relay/fuse with Pin 1 bent over the side and the wire lug attached. I will try better pics tommorow when the sun is still out. |
that's weird. your relay is black and mine is white. i wonder why the difference?
That is wierd...... Did you already do this mod? I have a couple of white relays in my box too.... are you sure your modifying the righ one?... unless you already did this mod, then of course you grabbed the right one.
doesnt work on FX4's !!!!!!!!
ANYONE KNOW HOW TO DO THIS ON AN 04 FX4 ???? THE R202 PIN 1 TRICK DOESNT WORK, TRIED IT LAST NIGHT. BUT,,, ON PAGE 196 OF MANUAL IT SHOWS ANOTHER R202, ITS IN FRONT OF THE COLLANT RESIVIOR??? THANKS FOR ANY INFO.
