billets grill
Originally posted by Merek3CS
oh wait, i misread that question bad..... a complete change for the grill once again takes time, I'd suggest taking it to get it done somewhere
Originally posted by ford2004F150
CW Grill here.....
What true pain in the a$$ to install!!!
But the looks are worth it.
CW Grill here.....
Originally posted by jdmclemore
But I assume that because the CW grill is a replacement, that you could concievably put the original honeycomb back in, correct? There are no permanent cuts you have to make by installing the CW grill, right?
YES you can go back to stock....
To install the grill you must remove the center plastic peace (honeycomb thing) from the outside trim (crome peace in you case).
There are a bunch of stupid clips you gotta bend and pop loose.
You drill two holes to in the bottom of the trim peace to mount the billet. Not noticable at all with the hood closed. NO CUTTING AT ALL!
Then you fit that trim peace on to the billet and mount it all back on with some beefier support brakets that come with the grill.
The directions are NOTHING like the install. You should throw them in the trash first thing! The way the diagram illustrates how it is mounted to the hood is WAY WRONG. It took 4 hours to figure out that the directions had me doing it all wrong.
-f2f-
-f2f-
-f2f-
The CW will be my choice if I decide to go billet. Still not sure though...I kind of like the look of the honeycomb with the chrome surround. It gives it a "sunken-in" look where a billet grill makes the front look very flat. Hmm.....
