04 front suspension
Does any manufacturer make a leveling kit that does not merely extend my bone stock suspension (such as a daystar or ez lift)? I guess i mean something more complete, like the stuff that goes into a 4 or 6 inch lift, but designed for front only, and approxamatley 2-2 1/2 inches of lift.
Skyjacker makes a 3" lift kit. It uses longer coil over shocks in the front to accomplish this. They are high performance aluminum bodied shocks. This is what I'm going with pretty soon. There is also an optional "add a leaf" for the rear, but I've heard it really isn't needed.
It's not cost effective for someone to make it. A daystar/autospring do the job so well and are so darn cheap, why over-engineer a solution that nobody (you excluded) will buy? Level kits rule, and if you need more, then Rancho, Pro-comp and others have products to meet your needs.
I doubt you'll ever find such a product.
The thing is you dont need a new spindle for only 2-3 inches. The steering geometry can be preserved with spacers alone. D is right, there is no market for it. Even the 6" lifts use spacers (some of them) so they still are doing what the daystar is.
Actually I know of two very reputable race shops making a 2.5" C/O replacement that will make the truck much more off-roadable. Camburg is one and Donahoe is the other. Fabtech is also releasing it's 2.5" Dirt Logic C/O soon. All of these will give about 2.5"-3" of lift. Camburg will also be offering a different upper arm that will not bind on the spring at full droop.
-Tim
-Tim
Much more off-roadable?! I call BS! Much more off-roadable is 4-6" of lift, 35s, higher gearing and underbody protection. Not a still over-done kit that moves some suspension geometry a degree or two...
Custom race shops will do anything you desire, so long as you have the $$ to pay for your desires. Like I said, there isn't a mass-market for it.
Why would you spend $1000 on a coilover that isnt providing you more than 3" total and only in the front? A full blown suspension kit would be around $1300-$1500 and the capability would be far more superior.
Originally posted by dzervit
And are the going to cost $150?! Not bloodly likely.. and a few select people will actually use the capability... they will not be good sellers and ulitmately dropped, or at least extremely rare.
And I disagree with you when you say a 4-6" lift is the way to go to make a truck more off-roadable. Dropdown brackets and a high center of gravity is not exactly ideal when off-roading at speed. If your going to go rockcrawling then the aftermarket coil over may not be for you. If your going trail riding then it might be a toss up.
It completely depends on what you want to do with your truck.
-Tim
I think out definitions of "off-roading" are a direct result of where we live...
While I think it's insane do get a 2.5" lift with slightly longer coilovers, I guess if I was surrounded by desert and would 'off-road' at 40-60mph I may reconsider. 'Round these parts that would just be stupid to do, a nice lift and the other things I mentioned would kick the snot out of the camburg setup... again, a direct result of the 4-wheelin' states we live in.
I think the majority of guys here mean trails, mud and some obstacles when talking about 4 wheeling. Very few are for Baja and Rock Crawling, as these trucks weigh too much, and have a wheelbase far too long.
Dzervit is right, a 4-6" lift is going to really help you in the offroad department. I have done both with my truck and the better ground clearance makes the lift worth every penny. The higher center of gravity is a joke, who is going to race their truck offroad ,over dunes or rock crawl with insane camber angles.
A new coilover is going to provide you better performance and articulation but give you little to no clearance gains (which this truck really lacks).
A coil over for $1000 is insane and makes so sense what so ever. If you want a level truck, buy a leveling kit. If you want more performance and offroad ability, get a suspension lift.
