skyjacker lift question
Old Dec 6, 2004 | 09:09 PM
easterisland's Avatar
Question decided to get the skyjacker 2.5 spacer lift
I purchased the skyjacker lift spacers for the front springs. The pictures for these spacers look the same as the daystar brand. What differences are there between the two? Is one better than the other? The part #'s on the Skyjacker spacers were M03456 and M03457. The main part # was FF25
Install was pretty simple.
Old Dec 8, 2004 | 03:14 PM
Jack up truck
remove wheels 21mm
remove steering knuckle 13/16
remove upper ball joint to spindle 13/16
hit spindle with hammer and mine came apart
Old Dec 8, 2004 | 03:19 PM
remove upper strut bolts (except one)15mm
remove lower strut bolt 1 1/16
strut hangs until last upper strut bolt is removed
strut removed
Old Dec 8, 2004 | 03:21 PM
compress spring with autozone loan a tool deal
remove upper strut isolator mount 15mm open end wrench and cresent wrench
remove coil sping isolator it just popped out for me
remove studs I hit them with a hammer to remove them
insert new bolts which came with kit and pop new isolator into mount
Old Dec 8, 2004 | 03:55 PM
install upper strut isolator mount onto strut assembly
reinstall strut top bolts 17mm
I had to use a pry bar to get the lower strut mount in place to rebolt it in, but it did go. Didn't have to remove sway bar. I also used a big vice grips clamp to get the spindle aligned with the upper ball joint stud.
Total time for driver side about 1 hour with pictures and all. It took less than 1/2 hour for passenger side.
Sorry, forgot to take measurements, but it looks like the front is a little tiny bit higher than the rear...
Old Dec 8, 2004 | 04:25 PM
Before
After
Old Dec 9, 2004 | 12:57 AM
khendrix2374's Avatar
Pretty Impressive pics man. Good Job.
Old Dec 9, 2004 | 08:08 AM
wandell's Avatar
Great how-to pics!
Old Dec 9, 2004 | 01:03 PM
ConcreteGuy's Avatar
Comments and pictures were well gone...I enjoyed your story...
Old Dec 9, 2004 | 01:24 PM
Baja4x4's Avatar
Daystar makes Skyjacker's spacers so they are identical. Skyjacker just rebrands them.
-Tim
Old Dec 9, 2004 | 01:29 PM
kirkb's Avatar
What is main difference in the DayStar/Skyjacker leveling kit/spacers and the AutoSpring ones?
I can see from the install pics that the DayStar route requires compressing the springs - and the Autosprings do not.
While it appears they both give the same result in ride height, Is one kit better than the other in terms of reliability, strength, etc?
Thanks for any help you can give, as I really need to level out my new truck soon, I hate the hot rod, lifted back end look.
Kirk
Old Dec 9, 2004 | 01:49 PM
porkchop's Avatar
Autospring is a spacer between the spring/shock assembly and the frame.
Daystar is a spacer that becomes part of the spring/shock assembly. Compressing the spring for install basically pre-loads the spring and raises the spring rate but shortens it.
The former basically retains the stock spring rate and full range of motion.
Old Dec 9, 2004 | 02:14 PM
The daystar/skyjacker is two part.
Part one is similar to the autospring because it is mounted above the strut or "between the spring/shock assembly and the frame."
Part two, does compress the spring because it is installed between the spring and upper strut mounting plate.
see picture below
Old Jan 17, 2005 | 06:25 PM
with new wheels
centerline crossfire 17x8.5 with goodyear 305/70/17 mtr
2.5" skyjacer/daystar level it it doesn't rub turning full turn to either side but I haven't had it off road.
Old Jan 17, 2005 | 11:26 PM
4 da boat's Avatar
Nice truck Great photos
