Folding mirrors
Old Dec 16, 2004 | 10:25 PM
  #31
dzervit's Avatar
Originally posted by yob2kanobe
Big D, youve got mail
Alright.... I've gotten a ton of mail and nuttin' from you. Can you resend?
Old Dec 16, 2004 | 10:45 PM
  #32
yob2kanobe's Avatar
Done
Old Dec 17, 2004 | 02:03 PM
  #33
baja150's Avatar
Originally posted by Sandog53
Guys, you dont need the module. I checked one out today. All the module consists of is some on board relays. You can buy a relay and make this work. All you need to do is pulse a grd when you hit the switch and the mirror will fold. It is alot easier than you are making it out to be. The five wires can be used on a std relay.
Yes the PFMM does consist of 2 relays, but also a limit sensor. If you don't have the limit sensor you have to manually stop the mirrors when they fold all the way in or out. With the limit switch they will stop by themselves so the motors don't continue to run after the mirrors are at the end of their travel.
Old Dec 17, 2004 | 02:06 PM
  #34
baja150's Avatar
Question- you said "the PFMM is behind the rear seat on the drivers side near the corner" Can you be more specific? Is this behind a panel? Thanks
You have to remove the seatback and c-pillar trim on the drivers side. It's a little higher and rearward of the seat belt retractor.
If you don't have a King Ranch then I'd put the module somewhere else under the instrument panel.
Old Dec 17, 2004 | 02:07 PM
  #35
baja150's Avatar
Originally posted by bsm2001
baja150 - see my email to you.
I'll check it and get back to you later.
