150 Keyless Entry Door Handle
Old Nov 20, 2004 | 10:58 PM
romeoz's Avatar
My 04 XLT has keyless entry but I do not have the keyless entry for the door handle. If I buy this part from Ford, which is not a bad price, can I install this on my truck to make it keyless entry on the door handle? Thanks
Bryan
Old Nov 20, 2004 | 11:25 PM
Rockpick's Avatar
Moderator &
First, I appologize for not knowing the answer to your questions but, I did want to point out that there was a key pad for sale on ebay...
Thought that might save you a buck or two.
RP
Old Nov 20, 2004 | 11:29 PM
05 150 KR's Avatar
Keyless Entry Code thread
Check out this thread and see if it helps, if not do a search I remember reading something about this.
Old Nov 20, 2004 | 11:43 PM
jhartz's Avatar
all you have to do is cycle the ignition 8 times and wait for the door locks to cycle, then hit any button on your key fob, then hit any button on the new door pad, and its programmed.....
Old Nov 21, 2004 | 09:17 AM
romeoz's Avatar
so the keyless door entry pad does not need any wires? I was told by Ford it had wires hooked to it...but then again they guy said he thinks it did I was searching thourgh here and saw some people install these on 03 on down and there was wires they connected..but I cant find anything on the 04 model..and I fond that on Ebay..15.00 with less than a day to go..I think I will bid on that...thanks for looking out
Bryan
Old Nov 21, 2004 | 10:01 AM
jpdadeo's Avatar
Old Nov 21, 2004 | 10:04 AM
05 150 KR's Avatar
romeoz,
Let me understand, you have the keyless entry on your truck now (came that way with the truck). You just need the code?
Old Nov 21, 2004 | 10:22 AM
KC8FLB's Avatar
The keyless entrypad that is on the door from the factory, is monted into the door and has wires.
You can buy a easy mount aftermarket ford keyless entry doorpad from the dealer, if you didnt get one from the factory. From what I have rear this one just sticks to the door, uses batteries and doesnt require any wires to be run.
Old Nov 21, 2004 | 07:34 PM
romeoz's Avatar
I dont like that easy mount one..I saw that at Ford but I want the Factory look....Do you know if the 04 F150 XLT that has keyless entry is pre wired for the keypad in the door handle? If someone knows that would be better than having to take my door panel apart. thanks
Bryan
Old Nov 22, 2004 | 08:46 AM
04XL4x4RC's Avatar
Try www.fordpartsnetwork.com email them and let them know what you are looking for. They always come up with Ford Part numbers for every thing I have inquired about.
I am getting ready to finish my install of power mirrors that I acuired from them and also the switch. I am not sure if everything else is already in the doors for power or not but I am sure I will find out in the next week.
Good luck as this is also something I am really interested in doing myself.
Windows and doors locks to come soon.
Old Nov 22, 2004 | 08:51 AM
nightmoves's Avatar
I know up untill the new body style change the 150 with power door locks were pre wired for the door keypad.Not sure on the new style.I would just pull the door panel and take a peak.You can also get the stick on type.If you don't like it on the door you could place it anywhere on the truck.Inside the bed ,behind the cab etc..
Old Nov 22, 2004 | 10:02 AM
04XL4x4RC's Avatar
Fordparts network has the keypad right now for $119..
http://www.fordpartsnetwork.com/cata...splay/422.html
I have also emailed them to see if they carry the door handle with the keyfob/pad or if it multiple parts. The outside handle w/keyless is only $59. on there online catalog. Not sure if that comes with the pad tho.
Old Nov 22, 2004 | 04:31 PM
04XL4x4RC's Avatar
Email from Torrie at FPN.
"Correct part numbers to order :
4L3Z1522405AAA
4L3Z14A626AAA
Take care,
Mr. Torrie R. McPhail - (Owner)
http://www.fordpartsnetwork.com"
4L3Z1522405AAA - $49.49
4L3Z14A626AAA - $39.62
This is for regular cab 2004 F150 Driverside door hadle and actuator.
Hope that helps everyone!
