Front Locker/Limited Slip ?
Has anyone purchased or is anyone planning on getting Lockers or some sort of limited slip for the front. I am interested in getting something that I can have and still drive daily n the road.
Also, how is the central hub utilized. Is it limited slip or is it lockup so equal power goes to front and back? If not, how does that get imroved if possible?
Originally posted by EddyG88
I am pretty sure the front is already a constant locked system isnt it? Both wheels always have to turn at the same rate in the front. Otherwise you could drive in 4wd all the time with no problems. Right?
But am not sure.
Is it locker or not in front. I didn't think the front was a locker, but could be wrong.
also, what is the center differential? Is it locked like the LR's and LC's or Limited Slip or?
Originally posted by Dr No
The center diff (transfer case) is open when in 2W and a solid with no slip when in 4W. Does that answer your question.
Mike
Mike
The other part of the question was the FRONT DIFFERENTIAL. WHAT IS IT????????????
I don't think it's a LOCKER!!!!!
I don't think it's even LS????????
So it must be non-LS. Which means, can you say GET STUCK!
So if all of the above are true and the fron't diff isn't LS or locker, then who makes an LS or locker than can be used turned on/off with street driving use, so as not to damage it.
sorry if I double posted, but thi system seems to be working strangely today
AS FOR the CENTER DIFF. Do you really think it is locked? You sure? Or it makes sense, which is not always the right answer. I remember an old Jeep commercial, where the jeep truck was the only truck that could pull itself free when both rear tires were off the ground, which means that the center diff on Ford, Dodge and Chevy were not locked or even LS for that matter.
Things have come along way, but no one speaks of this. Everyone speaks of big tires and lift kits, but a lowslung range rover will outcrawl any 12 inch lifted truck that has no LS front center or back. All show no go is no good.
the front is an open diff the tire with the least amount of traction will get all the power wile the one with all the traction will stay put, trust me on this, for the 8.8 ifs front end a few people make a selectable locker for our front ends and i recomend a selectable locker for drivability reosons, arb, eoton, and auburn gear all make selectable lockers the auburn gear ected is a lsd with full locking abilaty but it has a high preload so it is still very drivable,
Sounds to me like some of you are getting locking hubs mixed up with locking differentials. Just to set the record straight, the f150 has an open front differential. If it was locked, then you would not have only 1 wheel spinning at a time as big truck explained. It would also be considerably harder to turn and you would get a popping noise from the front when the wheels are turned sharp. The rear end in the f150 has a limited slip (most 4x4's do, anyway). It will turn both rear wheels to an extent, but when it gets in too much of a bind it will only allow one wheel to turn, like the open diff. The only way to ensure that all four tires spin at the same time is to have front and rear lockers. A selectable locker, like the brands big truck mentioned, would be good for your application. You may also want to consider an autolocker, like the detroit ezlocker. As long as you don't get a spool or have it "lincoln locked" you should be able to have a pretty streetable unit.
