Musty smell from AC
Old Oct 1, 2004 | 12:14 PM
KHUGHES53's Avatar
Musty smell from AC
Wonder if anyone else was experiencing this....when i turn on my AC i smell a really musty smell for 30 seconds or so and then it tends to go away......I'm just worried that the unit has a puddle of condensation in it and growing mold.......is this something that I can B**** to the dealer abaout? thanks in advance!
Old Oct 1, 2004 | 12:17 PM
Mike99a's Avatar
I have the same problem but have never bothered to investigate it any further, might ask the dealer at my next service.
Old Oct 1, 2004 | 12:41 PM
mjninke's Avatar
AC
Has anyone ever had a car that didn't do that? Or a home heater that didn't smell like burnt dust after it fires up for the first few times of the year... I would consider that "Normal Operating Char."
Old Oct 1, 2004 | 05:03 PM
mornargo's Avatar
The problem is condensation, almost all cars have it.
The condensation turns mold,and thats the smell.
Solution...put the vent, just outside air, no a/c, on high, then spray Lysol deoderizing disenfectant into the vent were the hood meets the windsheild. This will kill the mold growth.
Do this once a month or so and it should stay fresh.
You need Lysol because it kills germs regular sprays dont.
R
Old Oct 5, 2004 | 12:25 PM
Keener's Avatar
From experience when living in Daytona, running the a/c with the windows down or fresh intake on, in high humidity, will give that old sweat sock smell.
Don't run the a/c with windows down, recirculate the air instead of fresh air, and try the Lysol trick.
Old Oct 5, 2004 | 04:40 PM
Blk98stang's Avatar
Mine does it too. Doesn't bother me too much, but I'll probably try that lysol fix.
On a side note, none of my other cars have smelled as musty as my truck.
Old Oct 5, 2004 | 05:25 PM
mornargo's Avatar
Also before you turn off the a/c and get out, turn off the a/c, and let the vent with just outside air run for 3 or 4 minutes, this will prevent the condensation from building up.
Old Oct 5, 2004 | 07:24 PM
Blk98stang's Avatar
Thanks for the tips!
Old Oct 5, 2004 | 07:28 PM
SuperCab V8's Avatar
mornargo, Thanks for the tip buddy....... i heard also if you ran the heater for 5minutes it would fix the problem as well? your tip is still better though. and it leaves a nice lemon fresh smell!
Old Oct 17, 2004 | 07:58 PM
KHUGHES53's Avatar
Thanks to all who posted....problem solved
