mud flaps and wheel well trim
Old Sep 1, 2004 | 01:29 PM
skiffrider's Avatar
which mud flaps do you guys recommend.. I have a supercab xlt looong box with the platic stock running boards, no wheel well trim (although, I may want to add it) any advice on where to get the well trim and good flaps? are ford accesories the way to go here?
Old Sep 1, 2004 | 03:11 PM
J-150's Avatar
unless you feel you really need them, I personally find them ugly.
I think it looks better with just wheel lip moldings (that you can get almost anywhere)
Old Sep 1, 2004 | 07:27 PM
Bad99Pony's Avatar
I got the Husky Mud Guards and had them painted to match the Arizona Beige
Old Sep 1, 2004 | 07:54 PM
TUFF FORD's Avatar
I got the ones from Ford. I like the way they look, price was fair and you can get them from your Ford dealer.
Old Sep 1, 2004 | 08:05 PM
JohnAndDar's Avatar
Bad99Pony,
I meant to tell you in an earlier thread, but got sidetracked..your painted mud flaps look great.
I talked to a paint and body shop last December about painting my running boards and mud flaps Az. beige...but they were concerned about the paint holding onto the surface over the long term and turned me off on the idea.
Did the place that painted yours have to do any surface prep/sanding?
Thanks,
Old Sep 1, 2004 | 10:22 PM
Bad99Pony's Avatar
Thanks John... I did actually ask them about the paint coming off and pointed out the instructions said to lightly scuff them before paining. The owner said that wasn't necessary, something in the paint they used would make it stick to the surface with no problem. They've done work for me in the past and I've had no issues with them, only time will tell on these tho.
Old Sep 2, 2004 | 10:38 AM
bluestang67's Avatar
I just made a thread on step bars and molded mud flaps > I see Bad Pony your fronts looks as if there is a place made for the factory step bar. Bad they use a plastic adhesion promotor to assist paint in sticking same as on the bug shields that are paint to match. This product i think it softens the plastice so the chemical in the paint will bond together for better adhesion. I dont think under normal driving you will have a problem. If the flap gets bent in half it might crack paint or begin to peel.
Old Sep 2, 2004 | 11:39 AM
Bad could you send me a pic of the inside of flap. Seen the fords and they have a hollow look yours look faced on both sides ??
