Window regulators
Window regulators
I got power windows on my 04 SCAB and every few weeks of use I get this black greasy stuff on the inside of my two front windows .What is the deal and what works best to take that crud off. glass cleaner doesn't cut it .
There’s a thread somewhere about that in the 2004 forum. If I remember correctly, there was part of the window track that was out of place and had to be fastened so it didn’t rub the glass. If I find the thread, I’ll post it up for you.
If you don't have time to go to the dealer or you don't want them messing around inside your door. The Mr. Clean Magic eraser works fantastic on this grease. I have it on both window and every couple of days I take the eraser out of my center console wet it, ring it out and rub the stuff right off.
edit: I have the window tinted and it has caused NO problems with the tint film.
Door's
Guys... It seems as though some people in the forums get excited when the Dealers hack their turcks apart. These doors will never go back the same once opened up. The plastic gets cut and pasted back on... Those trim tabs will never fit the same again...
The dealer balanced my tires 4 or 5 times and I have the marks on my wheels to prove it...
My gas door broke, so they replaced the unit, and reused my gas door... Now my gas door has pry marks on it...
Unless you have major problems, or quick fixes, maybe hold off, use mr. clean or something...
Re: Door's
Re: Door's
I know it's a pain sometimes to get to the dealer but, you're either gonna spend your time at the dealer or spend your time fixing the problem yourself. Personally, I prefer to spend my time at the dealer. I've spent too much money on this truck to spend my time laboring on some sh*t that FoMoCo should be fixing.
Re: Door's
drillsgtjra, it's warranty work. Why not let the dealer fix it. If they break it they have to replace it. If you break it it comes out of your pocket.
I did watch them while they worked on mine. It is a pain in the butt to R&R the panels. Another reason for the dealer to do it.
Re: Re: Door's
