315X70X17 with daystar 2.5 lift ?? Will this work?
Old Jul 18, 2004 | 09:49 AM
rodnash's Avatar
I just got the daystar 2.5 leveling kit...........can you put 315X70X17 BFG At's on this, any rubbing?
Does any one have this?
Thanks for pictures or any advice.
Rod
Old Jul 18, 2004 | 12:43 PM
04fordman's Avatar
Rodnash,
I have a six inch lift on my truck and those same size of tires you are looking into using. I had to cut part of the plastic under the front bumper because it was rubbing. Right now I don't have any problems with it rubbing.
Hope this was helpful.
Check out my pictures.
https://www.f150online.com/galleries....cfm?gnum=3897
Old Jul 18, 2004 | 02:07 PM
wandell's Avatar
I just posted an answer in the tire and wheel forum to your question. Keep in mind that a lot of things play a part in tire fitment other than lift height. The 6 inch lifts that I have read reviews on (Skyjacker, Pro Comp and Fabtech) all state that they increase the front track width. Also, what wheel width and backspacing you use plays a big part in fitment. The trucks I've seen with the Daystar lift and 35's all had the stock wheels. I have seen one truck with the Daystar lift, 305/70-17 (34x12.50) MTR's and 17x9 inch Eagle wheels. The 34's fit with only minor trimming.
Old Jul 18, 2004 | 02:29 PM
rodnash's Avatar
04fordman and Wandell
Did you run these tire before the lift???
Thanks Guys
This is going on a 2004 SCREW 4x4 with daystar 2.5 leveling.
Thanks for th help. Do you guys think this will work???
Maybe I should go smaller???
Rod
Old Jul 18, 2004 | 07:06 PM
nitzer280's Avatar
A small suggestion: trust what Wandell says. No one on this forum knows more about tires, wheels, backspacing, lifts, clearances, etc. than he does.
Old Jul 18, 2004 | 08:31 PM
Dan McDan's Avatar
Check out Chemgod's truck. He has the 315/70/17's on stock rims with the front Revtek lift which gives similar height to the Daystar and he says there's no rubbing. I can't recall the name, but there was at least one other truck with that set up and he claimed no rubbing as well.
Old Jul 18, 2004 | 09:36 PM
chemgod's Avatar
Dan McDan is right, I have pretty close to that set-up with the 2" Revtek leveling kit. I've had it for about 8,000 miles now and it still handles well and I haven't had a rub yet.
I put a 9,500 pound WARN winch on it now too. I need to update my gallery with all the mods I've got now.
