how to fight brake dust!
ok this brake dust is killing my wheels. is there anything out there to stop it! please help! ive heard of some brake discs you can bolt on but i cant find them anywhere...
I use the Kleen wheels and really like them. Have used them on my last three vehicles. One interesting thing is that while I was at the ford dealership the other day, I found that they were selling them right in the parts department. Here our some pics.
I would say 95%. The wheels get dirty about as quick as my truck. I purchased the set of four but most put them in the front only. Personal preference. The only other options are to clean the wheels everday (which I found rediculous), or get dustless pads.
If they have not already come out with them, ceramic pad are the way to go. The dust is more of a brown color, and since it does not have the metal content of semi-metalic pads, it will not "stick" to your wheels as much. And, it is supposed to have better stoping power, since they disipate heat better.
Does anyone actually wax the wheel? I haven't yet on this, but it might make it so that the dust flows right off if you squirt it with a hose. I wish I could wax the white lettering on the tire. That's more annoying to clean than the wheel.
Also, has anyone noticed a reduction in dust as you've gone higher in miles? I haven't yet and I'm at 10,000+.
I wax the wheels of every vehicle I own. I use Zaino, which is a little time consuming, but seems to have the best durability by far. You can simply hose the wheel down with water to remove most, if not all brake dust, etc.
If you guys think that the F150 puts out a lot of brake dust, you should see the wheels of an X5 after about a week.
Hope this helps!
Hope this helps!
I had my tires flipped around for $40 at discount tire. Took about 30 minutes and was some of the best money i've thrown at this thing.
I have also noticed within the last couple months my brake dust problem has started to ease off a bit. I'm probably metal to metal but hey, no more dust. I'm at 18,500 with a majority of that being highway miles and i never drive in traffic.
One thing I've noticed around here is that ALOT of Expedition owners don't clean their trucks often (or well).
I see alot of Expeditions that look like the front wheels are matte black...
do they completely eliminiate brake dust?
Or are they???
