Where is the safety catch?
pin
Yes, that is what the straps are for. Why the pin is there I have no idea, but that is what I was told by an engineer. I do know that sometimes it does help when putting together the hardware for the tailgate.
The pin doesn't have anything to do with the lift assist.
The pin is to prevent the tailgate from hitting against the bumper if you have the straps on the side disconnected.
The straps do the same but are more for holding any weight that is placed on the tailgate.
Yeah, I can't understand why some do and don't either.
The "accident" theory seems a little weak. If they were accidentally putting parts on trucks, I think we would be noticing lots of other things that should or shouldn't be there. I wish they "accidentally" put the FX4 gauge cluster on my truck :-). Though I am sure there is sometimes a mistake here and there with some stuff. This pin seems too commonly found on trucks that don't have the bed extender for it to be accidental.
- Justin
- Justin
pin
ok, that makes sense. I pin that costs Ford probably 50 cents is a lot different than an instrument cluster that costs a heck of a lot more. Maybe "accident" was the wrong word. How about "mistakingly", "in error". Whatever sounds better to you. Anyway, they are not putting the pin on "in place of" another part like the gauge cluster, but what do I know, I only build them.
Accidents/ mistakes do happen.
Remember the thread where some 200x year models of the Screw had reflectors only on the front interior door panels instead of the half light/ half reflector? they even had the wiring to plug the light in, just no lights.
Someone checked the trucks on the lot, and some had lights and some did not.
Someone should test it out. Take the tailgate straps off and let the tailgate fall and see if it hits the bumper, then stand on it to see if it will hold your weight.
(WARNING: This TEST should only be preformed at the dealership, without their knowledge)
