Ride getting more bumpy?
Old Nov 17, 2003 | 03:09 PM
Dupuis's Avatar
There is also a sticker stating correct tire pressure on the inside of the fuel door.
Old Nov 17, 2003 | 03:15 PM
BHibbs's Avatar
If you run 45psi in your tires they're going to feel like crap. Run 32-35 and they'll ride nice. The ratings on the sides of the tires are MAX. Run Max if you're hauling heavy loads. Not riding around town.
A "Bumpy" rough ride is definitely NOT a characteristic of this truck. It's actually quite the contrary...
Old Nov 17, 2003 | 03:22 PM
Dupuis's Avatar
I agree, 35psi in mine and it rides better than my 03 Exp.
Old Nov 17, 2003 | 03:45 PM
deep6blue's Avatar
But correc tire pressure is not ~just~ about the ride. It is about maintaining the tire tread correctly on the pavement.
To much pressure will cause the tire to wear on the center of the tread. To little pressure and the tire will ride on the outer edges of the tire.
The tire pressure is listed on the B pillar, on the fuel door, and in the drivers manual. Which one is correct?
This pressure issue really needs to be sorted out.
Old Nov 17, 2003 | 04:18 PM
BHibbs's Avatar
They all say 35psi.. What's the issue?
Old Nov 17, 2003 | 04:51 PM
jhcir's Avatar
I had my 04 back twice because of the ride. The first time it was the tires needed to be balanced, the second time they said they made an adjustment by rebalancing the back tires again. The truck does ride ruff when you hit bumps. Also I noticed at speeds of 65-75 the steering wheel shimmies (sp) back & fourth. I have to say after 2000 miles I'm not as happy as I was when I first got the truck.
Old Nov 17, 2003 | 10:06 PM
geo036's Avatar
Originally posted by geo036
45 PSI may be too high...however the tires themselves are rated for 50 PSI MAX cold. I would be worried about riding these things too low...for instance what I have them at now 36psi cold. Thats 11 psi low. I believe that the cert sticker on my lariat 4x4 reads 45psi recommended...I'll have to take a look at it again...but I'm 95% sure its 45psi
yep that 95% will get ya every time...40 it is
40psi recommended on the 18" LT275/65/18 GY's
Old Nov 17, 2003 | 10:10 PM
Toyota Sucks's Avatar
The"B" pillar. It's based on the tires ordered when built. It's a fed requirement.
Remember to check the tire pressure when their cold. The sticker indicates "cold" pressure.
The tires themselve sometimes (dependant on the tire manufactuer) indicate max pressure- which you don't necessarily want.
Old Nov 17, 2003 | 10:12 PM
geo036's Avatar
Gotta agree with ya...trying to sort through all the potential problems is starting to take its toll on me...Between paint defects I've found on my truck to the steering wheel rub/noise, to the kind of hard to explain (not really bumpy but not really smooth) ride, to the engine hesitation when the engine is cold, to the rear end/tire vibration when the vehicle is cold, to poor quailty leather...I kind of wish I would've just leased this one too...oh well live and learn...I like the truck over all....but the joy of having it is wearing off...
Old Nov 17, 2003 | 11:34 PM
Dondo7's Avatar
Hmmm, If you read the Tundra Thread, F150's are the greatest thing that's come about since the invention of Beer and Prostitution
Old Nov 18, 2003 | 06:21 AM
jhcir's Avatar
Yeah I expected more but It's still a nice truck. 2 months ago if some one said nice truck I was like oh thanks and talk to them about it & answer questions and let them look it over in & out. Now I'm just like thanks and I walk away.
Old Nov 18, 2003 | 11:55 AM
BHibbs's Avatar
So the entire truck sucks because you have a tire out of balance and you choose to run too much air pressure?
Old Nov 18, 2003 | 01:51 PM
jhcir's Avatar
I never said anything about my air pressure. So don't put words in my mouth, the air pressure is fine. It was the first thing I checked. The balance was way out & on a new anything there is no excuse. The ride is not living up to what it was suposed to be. It seems to me that my 03 Lariat drove better then this truck. Could there be a problem with the front end or 1 of the tires? Maybe will see when it goes back for a third time
Old Nov 18, 2003 | 02:05 PM
BHibbs's Avatar
My bad..
It is a shame you're having problems with what Should be a straight forward thing. But you know how that goes. Maybe it is something more serious. Definitely keep us posted.
I can definitely see (Not You, but others) how if you run too much air in these 18 inch, 65 series tires, you could get a pretty rough ride.
Old Nov 18, 2003 | 09:45 PM
rdotson's Avatar
I'm running 40 in mine, that's what is says on the fuel door. I'll have to drop it down to 35 and see what happens.
