salesman says no female plug in tow package
Old Nov 14, 2003 | 01:55 PM
jpmpd's Avatar
Unhappy salesman says no female plug in tow package
jsut got off the phone with my salesman,, had the tow package installed on my 2004 xlt,, looked through out truck for the 7 pin female plug to wire to my trailer and which would plug into the 7 pin plug installed on the truck,, could not find,, called salesman and he says they don't give you the female 7 pin plug and that i would have to buy my own,, does this make sense,, it's a tow package,,on my 93 when i got it i got the female plug to attach to the trailer ???????? why would they just install the male plug on the truck and tell you to get your own female,, isn't it a kit ??
thanks guys for any info
john
Old Nov 14, 2003 | 02:10 PM
Fasteddy's Avatar
Yeah, I got the same package. No female 7 pin, had to use an adapter.
Old Nov 14, 2003 | 02:15 PM
petard's Avatar
I got an adapter, I found it in the glove box.
Old Nov 14, 2003 | 02:24 PM
freddy40's Avatar
same here, in the glovebox.
my female plug was cute too and she smiled.....heheheh
freddy
Old Nov 14, 2003 | 02:31 PM
Dupuis's Avatar
Just checked, what you found in your glove box is the harness and fuse to wire in the brake system under your dash, not the male plug you will need. Tow package from factory on mine, no female plug. They asume that the plug is already on the trialer you will pull.
Old Nov 14, 2003 | 02:32 PM
XCR440SP's Avatar
Are you talking about the brake control pigtail? If so they do come with the trailer tow package, but any adapters from the trailer plug at the back of the truck to other pinouts aren't included.
Old Nov 14, 2003 | 02:43 PM
Dupuis's Avatar
Yes, the brake control pigtail, and your right on your other point. I guess another reason you don't get one is because it's not attached to the truck, to easy to get lost before you get your truck from the dealer. It would be costly for them having to replace female plugs on trucks that would of had them missing or more to the point, it's not included to save Ford $$$$$
Old Nov 14, 2003 | 04:11 PM
Wolfman064's Avatar
I bought one on ebay for 10 bucks. My Lariat has a 4 pin plug wired in the back, but I like the 7-pin adapter better (easier to plug my trailer harness into)
Old Nov 14, 2003 | 04:22 PM
Trever Adamo's Avatar
my 03 latiet Screw came with a tow package and has a 7 pin conecter that hooks wright up with my trailer i have
Old Nov 14, 2003 | 06:03 PM
36fan's Avatar
My 00 XLT didn't have one in the glovebox w/ the controller wiring; however, I had test driven trucks that had the 7 pin to 4 pin adapter tossed in the glovebox. I called my salesman and he mailed one to me.
Old Nov 14, 2003 | 09:51 PM
Rockpick's Avatar
Moderator &
Ditto. They're on ebay all the time.
BTW, my 2001 SCREW didn't come with one either.
Old Nov 14, 2003 | 10:25 PM
w8n4sno's Avatar
If you are talking about that 7 to 4 pin adapter that came with the old f150s, you don't need it. My '04 has both the 7 pin and 4 pin plugs built right into the wiring harness. If you look just to the left of your hitch, there is the 7 pin connector we are familiar with, and next to that, the 4 pin connector.
Old Nov 15, 2003 | 12:07 AM
BHibbs's Avatar
Yea, that's what mine has too. Pretty much both of the standards. Although I did have to trim some of the rubber from around my 4 pin connector because it wouldn't connect properly because of the rubber boot surrounding it. No big deal though.
Old Nov 15, 2003 | 08:51 AM
jpmpd's Avatar
thanks for all the replys guys,, guess ford is not giving them out on the new truck,, i know they got them as it probably came as a package,, male/female 7 plug,, will have to get the female plug from a trailer store,, like the 7 pin,, easier to put in and better connection
Old Nov 15, 2003 | 02:56 PM
hmustang's Avatar
Glad to see FORD has both systems on the trucks now.
