1997 F150 4.6l no crank
Old Dec 3, 2021 | 06:08 AM
kpmink's Avatar
1997 ford f150 engine compartment fuse block
lol...yes i did that after i moved the truck under a car port. then i took out the GEM module..installed the new used one.. theft light, blinking no start...no power to solenoid on firewall...fuh!!!l..lol
thank you for the reminder though...
Old Dec 3, 2021 | 06:54 AM
projectSHO89's Avatar
projectSHO89
I noticed that also. the reason i was needing the diagram is because when the theft light is blinking and the headlight blinking and the horn horn honking one of those relays is clicking...I cant figure this theft system...
Here's the thread regarding the relay box: https://www.f150online.com/forums/to...cations-2.html
If the parking lamps or signals are flashing when the perimeter alarm system is triggered, the corresponding relay(s) in the aux box should also be clicking.
The 97 & 98 models had an optional factory perimeter alarm that included a starter interrupt relay, flashing lights, and a honking horn. Unless your truck had an aftermarket security system installed, that's the system that is being triggered. The relays under the hood are a red herring, not a problem. They're SUPPOSED to operate when the security system is triggered.
Did the security situation arise upon GEM module replacement or prior?
Old Dec 8, 2021 | 01:58 PM
kpmink's Avatar
im not sure ehat heppened but everything works again. but now i have abs and brake light on....lol...no biggy
Old Dec 8, 2021 | 02:19 PM
kpmink's Avatar
after GEM replacement
