5.4l 2 Valve - Engine Oil & Filter
Old Aug 14, 2020 | 01:13 PM
riderboy1961's Avatar
2001 5.4l 2 Valve Engine
I am buying the: Shell Rotella Gas Truck Full Synthetic Motor Oil 5W-20 & the: Motorcraft #FL820S Engine Oil Filter for my rig.
I have put a quart of Marvel Mystery Oil into the Crankcase to run for 100 miles or so, supposed to clean up the inside of the engine a bit and gain a little better gas mileage along with silencing noisy lifters and such inside the engine. This is my first time putting it into the Crankcase, I have put it in my gas tank for many years though with excellent results.
I have only used Shell Rotella in my Ford 7.3l Diesel - I have read great write-ups about Shell Rotella for gas engines as well.
To Anyone who uses the Shell Rotella in their gas engines..... Good Results?
Am I buying the Correct Engine Oil "Filter" for my engine?
(I am double checking... check twice, purchase once)
Thank You
Old Aug 14, 2020 | 04:51 PM
Yes, that's the best reasonably priced filter. 5W20 is the correct weight oil.
Don't use any additives after you change the oil.
