death wobble
Old Jul 16, 2019 | 10:55 PM
  #46
jimbo74's Avatar
5 Year Member
Not horribly worried about it right now. It's easy enough. I know I just won't have 4wd until I fix it.
Old Jul 17, 2019 | 07:21 AM
  #47
Fbird's Avatar
some FYI.... You can NOT remove the front axles and drive the truck!!!! YOU WILL DIE.
the front hub bearings on these trucks require the axle and nut assembly to hold the bearing together!!!
I did drive mine for almost 1 yr with the entire front diff removed .....but... i also tore apart the axle assemblies and re-installed the outer stubbs (and torqued the nuts)
Old Jul 17, 2019 | 10:58 PM
  #48
jimbo74's Avatar
5 Year Member
It'll be alright
Old Sep 27, 2019 | 11:08 AM
  #49
FordOwner02FX4's Avatar
Originally Posted by jimbo74
not sure if this should be here, or suspension, but here goes..... around 35-45mph I get a death wobble, still tracks straight, jsut its a lot of side to side movement.... what should I check? obviously suspension components, but just want to see if anyone else is having this issue? I am on 35s....
Did you end up figuring it out? I’m having the same problem.
Old Sep 27, 2019 | 12:01 PM
  #50
jimbo74's Avatar
5 Year Member
I did. Front end steering components were shot. Tie rods, idler arm, and pitman arm
