death wobble
#31
#33
Using the correct stuff really helps, lol
Did remove the 2× 8mm bolts holding the fan shroud on, gave me a little more room. Also took off the radiator mounts with the 10mm - didn't remove them, just gave me a few inches of upward movement
Pitman arm off.
I did slightly bend the puller, but even if I never use it again, the $16 was worth it.
Used a lot of pb blaster, some hammer love taps, and slowly kept advancing the puller. Was going to keep advancing until something broke, either the puller or the pitman arm.
Didn't even need to bust out the torch
Pitman arm off.
#34
#35
#36
ok, got the factory spec, for all the rod ends, it is 56-84 ft/lbs
for the box shaft, it is 173-233 ft/lbs
the idler arm bolt holes are 126-169 ft/lbs
the steering box bolts through the frame are 50-67 ft/lbs
on my right inner tre, I torqued it to 54, and was still way off the hole, I kept tightening it in 5 ft/lb increments until the next cotter pin hole aligned. I ended up @ 100 ft/lb! but I sure wasn't going back it off so....
#37
#38
Didn't count the number of turns. I got all new parts, and the sleeves are different widths than what are on there. But I am matching up the end to end measurement between the joint heads. The stuff I am replacing is actually all moog problem solver, I just think it wasn't maintained properly. I can tell my truck has had a hard life. Hell, @ 176k, I drive this thing like a 16 year old drives a new a Mustang his parents bought him....
I took a video of how much play was in the old pitman arm. It is insane, not only will the ball move if arm rotated but it can go up or down into the joint like 1/8"
#39
#40
#42
