death wobble
Old Jul 4, 2019 | 01:55 AM
jimbo74's Avatar
5 Year Member
what about other brand stuff than motorcraft?
moog any good? anything else? I do also see ACdelco, which doesn't make bad parts... although, aren't they chevy parts?
they have some other brands listed on rock auto too
Old Jul 4, 2019 | 08:27 AM
Roadie's Avatar
Moog appears to be the go to brand.
Old Jul 5, 2019 | 12:22 AM
jimbo74's Avatar
5 Year Member
Originally Posted by Roadie
You obviously need to check for looseness in the ball joints, tie rod ends, pitman arm, idler arm, and sway bar bushings. If you don't know how to check these, take it to an alignment shop.
might just go ahead and replace all of these......
Old Jul 5, 2019 | 09:32 AM
Roadie's Avatar
I was checking my Dodge Magnum before a vacation trip and found the tie rod ends needed replacement. I would have ordered Moog from rockauto if I had time but I didn't. I bought the O'reillys house brand because all the local parts stores charged 2 1/2 times as much as rockauto for the Moog tie rod ends. The house brand was about the same as rockauto moog parts. They are probably made in the same chinese factory.
Old Jul 5, 2019 | 10:06 PM
Fbird's Avatar
you MAY look at the upper ball joints on the "new" upper control arm assemblies. I see NOW they make them replaceable....only on AFTERMAKET UCA's
Old Jul 5, 2019 | 10:19 PM
jimbo74's Avatar
5 Year Member
So...... looking @ stuff, I think I want the greasable Moog Problem solvers, it's $50 an upper arm....
Old Jul 6, 2019 | 12:53 PM
jimbo74's Avatar
5 Year Member
So what about mevotech? They look decent. Oe is more expensive, but the other stuff seems decent. Heck, even the cheapest options are better than the poop I have now, lol
What about mcquay-norris?
Upper and lower balljoints/control arms appear good. No boots torn, and passed the 12/6 o clock test with the wheel jacked off the ground via the lower control arm near the tire.
All tie rod boots [inner/outer & left/right] are torn, and appear to have some play, saw the most play in the pitman arm with also torn boots, and a little bit in the idler arm.
Truck does have 35" tires, a lift, and 176k miles. So even just changing them to cheap stuff has to be an improvement
Old Jul 6, 2019 | 03:29 PM
jimbo74's Avatar
5 Year Member
ok, ordered... spent $215.67 from rockauto
all moog problem solver
left/right, innet/outer tie rods, and sleeves
pitman arm, and idler arm 2.5" holes
Old Jul 7, 2019 | 06:39 AM
Fbird's Avatar
Have you checked the lower ball joints for slop....would be a damn shame to get it half way apart and discover they are toast....plus you really need everything together to determine if they are sloppy
Old Jul 7, 2019 | 06:52 AM
jimbo74's Avatar
5 Year Member
Yeah. I did check. Checked the uppers and lowers first. I mentioned that at the beginning of that post.
Old Jul 12, 2019 | 03:02 AM
jimbo74's Avatar
5 Year Member
ok, so........ right inner and outer tie rods are on......
idler arm is removed....
the joint on the pitman arm to drag link is floppy, definitely the main source of my play
pitman arm will not come off the shaft! tried to cut into it like some youtube vids, and I ground into my finger...... scared to use the grinder at this point..... my finger is pretty chewed up
loosened the box, tossed an arm puller on it, started bending the jaws...... been soaking it like crazy with wd40.....
not sure what to do now... I contacted a mobile mechanic, and he said if it is seized, I will need to remove the box to avoid damaging it (which is actually what the fsm shows)
ugh!!!!!!
Old Jul 12, 2019 | 09:18 AM
Roadie's Avatar
Use a penetrating oil such as Liquid Wrench or Kroil. WD40 is not a penetrating oil.
Old Jul 12, 2019 | 10:46 AM
jimbo74's Avatar
5 Year Member
Will try to pick up some of that up after work or pb blaster
Old Jul 12, 2019 | 11:48 AM
Roadie's Avatar
I had another thought on this. After spraying it with penetrating oil, put the puller on it and leave it over night under tension. If that doesn't work, wipe off the penetrating oil and heat it with a propane torch. Propane torches are inexpensive.
Old Jul 12, 2019 | 04:06 PM
jimbo74's Avatar
5 Year Member
Ok, I guess I can try that before I just give in and pull the dang box.....
I was reading though, and lots of people said not to use the torch as I could damage the seals.
I do have a nice torch, haha, it is connected to a camping propane bottle
