12 valve Cummins swap
Old Mar 26, 2018 | 11:59 PM
RZA ZAR's Avatar
Just kinda curious if a 12 valve or even a 24 valve would fit in an 01 supercab f150 xlt that stock had the 5.4 triton in it. Looking for alternative motor swaps as Well
Old Mar 27, 2018 | 12:29 AM
MitchF150's Avatar
Check out the Youtube vid from Finnegan's Garage and his swap of a 12V Cummins in his old Chevy 1 ton truck...
Tight fit even in that rig! Can't imagine that going into an F150 where the old 5.4 had it's rear 2 cylinders are under the cowl?
Someone did squeeze a Ford V10 in an F150 before, so maybe anything is possible??
But, anything is possible with enough time and money..
Good luck! Mitch
Old Mar 27, 2018 | 02:52 PM
RZA ZAR's Avatar
Yea the back 2 cylinders are pretty much pushed up against the dash but I was looking for a diesel swap
Old Mar 27, 2018 | 03:03 PM
The only reasonable Cummins diesel swap at this time would be a 4BT. The 6 cylinder is just too long.
I think a 7.3 Powerstroke might fit.
Old Mar 31, 2018 | 01:13 PM
Yes, the 6 cyl is long. A 4BT is a better match for the truck. You don't want a huge heavy engine in there... then you need to start fabricating a better suspension. Either way, expect to spend some $$.
