Shudder between 50-60mph?
Old Jun 12, 2016 | 08:42 PM
F150redneck's Avatar
Im planning a 2hr trip in 2 weeks and behold my truck started acting up. I really only notice a slight shudder like im running over small rumble strips around 50-60mph. It doesn't shake violently but its enough to **** me off. I have no CEL and it does it when in OD and out of OD. If im cruising and slightly left of the throttle I can get it to shudder a bit. Gears shift fine, brakes and rotors are fairly new, Trans fluids along with all other fluids have maybe 15k on them, idles fine, if I am up to speed and mash the gas it does it as well. I just replace the COPs maybe 20k ago as it shows no sign of it being one of those going bad. Could it possibly be bad fuel or EGR issues? Id like to try to find this before my trip in 2 weeks. Any help appreciated!
Old Jun 12, 2016 | 09:25 PM
Forgot to mention ins a 01 F150 7700 with about 136k on the clock
Old Jun 12, 2016 | 11:26 PM
Bluegrass's Avatar
You have one faulty coil.
Need to use a Scanner to look at the data that will indicate which cylinder it is.
Since the fault is not 'hard', it will not set a code.
Good luck.
Old Jun 13, 2016 | 12:24 AM
Here are the only codes I got
p1460
b1450
b1467
c1284
TID 2a. phase 4 vapor gen max change
TID 2b. phase 4 vapor gen absolute rise
Old Jun 13, 2016 | 12:06 PM
Bluegrass's Avatar
If you want to clear the shudder, find the faulty coil.
The other codes are for 1460 is a wide open A/C control circuit failure.
B1450 and B1467 are body codes.
C1284 indicates oil pressure switch failure.
Good luck.
Old Jun 16, 2016 | 06:49 PM
OhioLariat's Avatar
I'll second Bluegrass' diagnosis as "likely." This sounds almost exactly like the symptoms I had in my '99 when a coil was failing. It eventually set a code indicating which one was bad. You *might* be able to identify the culprit coil by disconnecting them one at a time at idle. Good ones will drop the RPM. When you hit the bad one, nothing will change. This only works, though if it's actually bad, not just weak.
Andy
Old Jun 16, 2016 | 07:46 PM
If a coil is actually that bad, it will trip a CEL with a code.
How many miles on what brand plugs? What brand coils did you use?
Old Jun 16, 2016 | 10:56 PM
OhioLariat's Avatar
True. I should have stated that, as well.
Andy
Old Jun 16, 2016 | 11:15 PM
I have motocraft plugs and araparts coils. Both have around 20k maybe on them. I got to dig around the truck today to see what was the culprit. Come to find out it was a u-joint! Shudder is gone now. I will say the way it was acting it did indeed seem like a coil was going bad.
Old Jun 16, 2016 | 11:31 PM
Roadie's Avatar
Thanks for telling us what the issue was. I had a u-joint go bad in my 94 F150 4x4 with a vibration at the speeds you are talking about but I could tell that is was a drive train issue and not the engine.
Old Jun 16, 2016 | 11:39 PM
Yeah I've had them go bad before also but mine were a constant vibration. This is a first it did it at certain speeds. Glad I found it before I started ripping coils out.
Old Jun 17, 2016 | 02:30 PM
jethat's Avatar
Ford makes a pretty stout Ujoint on these trucks. They rarely fail. But these trucks are getting pretty old..
Old Jun 18, 2016 | 01:53 AM
OhioLariat's Avatar
Glad you found the problem, and glad you posted it. I, too, had a u-joint fail, but rather than being loose, it was siezed in one axis. The "shake the drive shaft test" was a misleading false negative in this case. The failure caused a driveline vibration, but like the other poster, it was over a wider range of speeds, and was obviously mechanical in nature.
Andy
P. S. I'd rather change a u-joint than a couple of those coils.
