F150 4.6 5.4 swap
Old Jan 17, 2022 | 09:10 AM
  #31
Caccia04's Avatar
FORD F150 4.6-5.4 Transmisson swap
Mr. Paxton, you sound like maybe the person that has had the most experience with my question. I bought a 1997 Ford F-150 4.6L Triton 176,000 miles to use the transmission for my moms 2002 Ford F150 5.4L Triton 141,000 miles. I heard both have the same bellhousing. Am i going to be able to put the 4.6 transmission into the 5.4 motor? With some adjustments? I would greatly apricate whatever wisdom you can give me, trying to help revive my moms truck as she needs one being in northern Minnesota.
Old Oct 15, 2022 | 07:31 PM
  #32
freeab's Avatar
Originally Posted by shaun emerson
Am i able to bolt up 4.6 headers to a 5.4
Unfortunately no when it comes to the 5.4 your stuck with only using 5.4 headers. The easiest way to tell if they are for a 5.4l the bolt holes are located in the center and top and bottom of the port. Others are either in straight line across or they are on a slight offset
Old Oct 15, 2022 | 07:59 PM
  #33
You replied to a 6 year old post.
