Complete 4R100 Swap Notes
Old Jun 14, 2015 | 03:33 AM
tfast150's Avatar
Originally Posted by illness95
couldnt you just buy a 4wd expedition and use dang near everything from it? i could buy a 4wd expy around here for probably as much as it would cost to buy most the parts seperatly.
Yes however the rear driveshaft would be shorter than required unless it was going into a rcsb. A scab sb or screw will have the same length though.
Old Jun 14, 2015 | 03:38 AM
tfast150's Avatar
https://www.f150online.com/forums/19...t-7700-kr.html
Old Jun 14, 2015 | 02:27 PM
OGTerror's Avatar
Thanks for posting such detailed information helps understand a lot of what was done to mine, too bad I only speak English and Spanish.
On another note maybe I should've asked this question: https://www.f150online.com/forums/tr...ml#post5153675 here instead of opening a new thread. At any rate, would you be kind enough to explain 14 and 15 in plain English or Spanish ( ) to me, please. Thanks in advance.
14) Gear shifter linkage
15) Range sensor bracket to attach linkage too. The 4R70 linkage is too short and the bracket is not the same.
Bracket looks like it is the right size but those that look like the old F-150's Gear shifter linkage?
