Plasti Dip
Old May 23, 2014 | 08:38 PM
AndersonS's Avatar
Plasti Dip
Has anyone plasti dipped their stock rims? Got any pics?
I'm considering doing this on my black FX-4 because the clearcoat is failing on 3 of my wheels.
Old May 24, 2014 | 05:52 PM
AndersonS's Avatar
Well... I couldn't wait long enough, so I dipped my wheels anyway.
What do you guys think?
My eBay wheel is still in good shape.
The factory clearcoat is getting hazy.
I didn't bother masking. The overspray lifts off...
... like snake skin.
Old May 24, 2014 | 05:57 PM
str8t six's Avatar
looks good man!
Old May 24, 2014 | 06:36 PM
nduffey's Avatar
did you uses the glossifier or just go with the flat black. I was think of doing the gray portion of the stock rims in glossed black for contrast. Ideas?
Old May 24, 2014 | 06:47 PM
Raptor05121's Avatar
Wow that looks REALLY good. I am thinking of doing that to my new wheels when they get here, just paint the inside lines:
Old May 24, 2014 | 09:28 PM
AndersonS's Avatar
Thanks guys. It was a pretty cheap way to know what my truck will look like if I ever want to powdercoat. Does anyone know if this stuff will grey in the sun without a top coat, or is it good to go as-is?
looks good man!
Nope, flat. I saw the glossifier on the shelf, but I was afraid it would make the finish too glossy. According to the can, the more you spray, the shinier it gets, topping out somewhere between a gloss and satin.
Just the inside would be sweet. The heritage rim is up there with FX-4 on my list of favorites.
Old May 24, 2014 | 09:33 PM
Toyz's Avatar
You will find that they will lose their shine over a month or so. Then they become a very flat black. At that point you may consider a few light coats of gloss.
Old May 24, 2014 | 09:57 PM
AndersonS's Avatar
I like way the wheels look now. Should I just go ahead and spray the glossifier now to maintain the finish?
Old May 25, 2014 | 12:32 AM
Toyz's Avatar
Not sure if that would help? I personally have not used the glossifier. But I have used plastidip on wheels and other things and know that it will fade in a short time to a real flat black. Right now, they have that powder coating look. That will go away
Old May 25, 2014 | 04:12 AM
archbot's Avatar
This looks so slick! Might have to do this to mine
Old May 25, 2014 | 07:58 AM
AndersonS's Avatar
Do it, then post pictures here!
You can always peel it off it you hate it.
Old May 25, 2014 | 12:13 PM
coobies5's Avatar
I pd'd my wiper cowl almost 3 years ago and it has faded a little bit, but my lower valence i did about a year almost 2 years ago and it is still black as the day i sprayed it. So if the piece isn't in direct sunlight it more than likely won't fade and also plastidip has changed over the years with UV protection and resistance to fading.
Old May 25, 2014 | 03:14 PM
Toyz's Avatar
They don't horribly fade. But that nice rich color will go away. Mine are 2 months old. Here are some before and after pics the day I plasti dipped mine. Nice bright/flattish black look. The last pic is a pic I took today. You can see how much it has faded in 2 months. If my wifes car was here I would show you the grill. It is pretty flat, much more than my rims. I did the grill about 2 years ago maybe. Both of our cars are kept outside.
I removed my tires and did the back side as well being you can see through these rims so much. LOTS of light coats. I used one can per rim.
Before and after on the Day I sprayed them 2 months ago
Pic I took today
I still love the look of them over the traditional wheels they were to begin with. But I liked the rich look of them more when they were fresh.
Old May 25, 2014 | 07:01 PM
coobies5's Avatar
you can actually use clear coat over them to retain that fresh look, it will however make it a bit harder to remove.
Old May 27, 2014 | 03:09 PM
AndersonS's Avatar
Pic I took today
That doesn't seem too bad, but it has lost that rich black color... especially being only 2 months old. Guess I'll spray some glossifier now and see where that gets me.
