2000 f150 power lock issue
Old May 1, 2014 | 10:57 PM
mjewell00's Avatar
my power locks don't work now along with my keyless entry. I can hear a click when I hit the button on the door but that's it. and the keyless doesn't do anything, no click no nothing. replaced the battery in the remote still na da. any suggestions?
Old May 2, 2014 | 12:30 AM
jethat's Avatar
probably need actuators that are cheap but they are a PITA to replace! Do they move at all?
Old May 2, 2014 | 07:28 AM
mjewell00's Avatar
they try to do what there supposed to but they just cant make It
Old May 2, 2014 | 08:02 AM
the_tool_man's Avatar
It seems unlikely that both door lock actuators would fail at the same time. Likewise, both door switches and the key fob wouldn't likely fail simultaneously. I'd get a wiring diagram and look for something in the control circuit.
Old May 21, 2014 | 10:21 PM
mjewell00's Avatar
I forgot to post back. but when I hit either drivers or passenger side switch lock or unlock I can hear the actuator try to go but only move a little. this happens on both sides either switch. click in the dash but if you hit the button too many times it fades away and stops. I think its the actuators
Old May 22, 2014 | 08:42 PM
JMC's Avatar
JMC
25 Year Member
I used something like this. http://www.eachbuyer.com/universal-h...E&utm_content=[Car+Accessories]&utm_campaign=[PLA]Canada%28EN%29&gclid=CP2z687nwL4CFaY-Mgod32EAPA
Old May 22, 2014 | 11:48 PM
I like Fords to's Avatar
one part every other part of your power lock / remote / keyless systems have in common is the circut breaker that the power locks use ( instead of a fuse which would burn at "end of travel" of the mechinism)
if the circut breaker is weak it might be tripping with less load than the lock actuators require
if you have power windows try swapping the circut breakers if they're the same -see if the problem moves to your windows
Old May 23, 2014 | 09:54 AM
ishootstuff's Avatar
I'm going with actuators. You can find out for sure by following this awesome DIY I made.
https://www.f150online.com/forums/el...uator-diy.html
Old May 24, 2014 | 10:19 PM
mjewell00's Avatar
it was the actuators both drivers and passenger side. replaced both Thursday works great now. keyless even works again
Old May 26, 2014 | 12:58 AM
hmustang's Avatar
In my old 2000 the actuator on the passenger side quit for a while then it started working again for a short time before it was done. I just lived with it since I didn't use the passenger side door much plus it still unlocked when using the key. Stayed that way the last couple years I had that truck when I traded it in for my 05 back in 05.
