Need help don't know what to do now
Old Feb 6, 2014 | 12:34 PM
  #31
Bluegrass's Avatar
You have one alternator, one power steering pump, one A/C drive clutch,
one water pump, one idler pulley and a belt.
If you take the belt off and noise goes away on a test run, what would it mean?
One or more parts has a dry or faulty bearing or operation.
Good luck
Old Feb 6, 2014 | 10:30 PM
  #32
cj92's Avatar
alright guys i just need to order it but i figured out it was the alternator not the idler pulley so other than that does my parts list look good? Thanks guys you've been alot of help
Old Feb 7, 2014 | 12:24 PM
  #33
I would not spend the money on an alternator if what you have is properly charging the battery. Let it whine till it starts making more expensive noises. Aftermarket offbrand alternators can be quite a crapshoot.
Old Feb 7, 2014 | 12:37 PM
  #34
jethat's Avatar
You can get cheap Idler pulleys for less then 20 bucks and they dont last forever. I replaced all mine a few years ago just so I knew they were good. If your doing diagnostics via parts replacement always start with the cheap stuff. Replace the idler pulley..
Old Feb 10, 2014 | 10:00 AM
  #35
cj92's Avatar
I did replace the idler pulley just waititng on the money to get the rest.
Old Mar 27, 2014 | 10:51 AM
  #36
cj92's Avatar
update truck is running like a top now new plug wires, fuel filter, belt, and alternator, found out a lot of her problems were coming from the factory muffler it was falling apart on the inside. so I cut it off and had duals with with a magnaflow muffler to give it a little growl
