Need help don't know what to do now
Old Feb 4, 2014 | 05:10 PM
cj92's Avatar
Originally Posted by glc
How old is the battery? Have you had it load tested? If it's getting weak, that can cause an alternator whine.
Did you replace the plugs, wires, and filters as recommended?
No i didn't because i replaced the plugs less than 5,000 and the wires less than 10k it probably wouldn't hurt to replace the fuel filter.. also how would i check if i have a clogged muffler or tailpipe?
Old Feb 4, 2014 | 05:11 PM
cj92's Avatar
also air filter is brand new.
Old Feb 4, 2014 | 06:10 PM
Take it to a muffler shop, they have equipment to test exhaust for restrictions and blockage.
Did you use Motorcraft plugs and wires?
Old Feb 4, 2014 | 06:30 PM
cj92's Avatar
I went with some plugs from autozone that ended up being the wrong ones so i switched them out for oem motorcraft plugs and autozone wires
Old Feb 4, 2014 | 07:05 PM
jethat's Avatar
That engine hate cheap parts. Mortcraft parts or BETTER and it hard to find better. Autozone wires are for sure not better. Just get rid of them. To many times guys have come in here with problems only to find they put cheap wires on. It makes a difference! Especially on the wires.
Old Feb 5, 2014 | 01:09 AM
Autozone Duracrap wires are exactly that. You can order Motorcraft wires from rockauto.com for about 1/2 the price that the parts stores want for them.
Old Feb 5, 2014 | 01:30 PM
cj92's Avatar
I know y'all are saying i should go with motorcraft wires but what about Denso? thanks
Old Feb 5, 2014 | 01:52 PM
No..........Motorcraft.
http://www.rockauto.com/catalog/more...161&cc=1354586
$60.79
$96.99 at Autozone, $88.99 at O'Reilly.
Old Feb 5, 2014 | 05:49 PM
cj92's Avatar
Ok this is what I'm looking at
Part Price Quantity Total
1999 FORD F-150 4.6L V8 SOHC
Belt Drive : Idler Pulley
DAYCO Part # 89048 {#89048FN} 90mm x 17mm Flat Steel, 37mm wide Drive Belt Idler Pulley
Flag indicates this part fits vehicles sold in the US Market. It does not indicate where the part was made -- manufacturers produce parts in multiple factories worldwide. Flag indicates this part fits vehicles sold in the Canadian Market. It does not indicate where the part was made -- manufacturers produce parts in multiple factories worldwide. Idler Assy. Pulley C
A Pulley Tool can be helpful when replacing this part.
$16.33 $16.33
Belt Drive : Belt
GOODYEAR Part # 4080990 8 Ribs / Effective Length 99" / Outside Length 99.75" Gatorback; Poly-V
Flag indicates this part fits vehicles sold in the US Market. It does not indicate where the part was made -- manufacturers produce parts in multiple factories worldwide. Flag indicates this part fits vehicles sold in the Canadian Market. It does not indicate where the part was made -- manufacturers produce parts in multiple factories worldwide. Accessory Drive; Poly-V; W/AC A
Do you also need a Belt Installation Tool?
$25.79 $25.79
Electrical : Alternator / Generator
USA INDUSTRIES Part # 507198 8 groove pulley included (Only 4 Remaining)
Flag indicates this part fits vehicles sold in the US Market. It does not indicate where the part was made -- manufacturers produce parts in multiple factories worldwide. Flag indicates this part fits vehicles sold in the Canadian Market. It does not indicate where the part was made -- manufacturers produce parts in multiple factories worldwide. w/ Opt Ford 130 Amp B
Do you also need Battery Cables?
$107.79 $107.79
Ignition : Spark Plug Wire
MOTORCRAFT Part # WR5934 {#1821880C2, 2Z10D840AA, F8PE12259LA, F8PZ12259LA}
Flag indicates this part fits vehicles sold in the US Market. It does not indicate where the part was made -- manufacturers produce parts in multiple factories worldwide. Flag indicates this part fits vehicles sold in the Canadian Market. It does not indicate where the part was made -- manufacturers produce parts in multiple factories worldwide. B
Do you also need a Spark Plug Boot Pliers?
$60.79 $60.79
Subtotal $210.70
Old Feb 5, 2014 | 05:58 PM
cj92's Avatar
$237 after shipping
Old Feb 5, 2014 | 07:48 PM
I wouldn't order an idler or an alternator till you can pin down exactly what is whining with a stethoscope. As I've said, a weak battery can cause an alternator whine, when are you going to get it load tested?
Old Feb 5, 2014 | 08:40 PM
cj92's Avatar
I got it tested battery is good.
Old Feb 6, 2014 | 01:09 AM
Okay, now use a stethoscope to localize the whine.
Old Feb 6, 2014 | 09:34 AM
cj92's Avatar
I've tried and can't seem to localize it.
Old Feb 6, 2014 | 10:36 AM
I'd get some help from an experienced mechanic.
