Knock on Start up
Old Oct 1, 2013 | 07:54 AM
02FORD4X4's Avatar
Knock on Start up
Well guys the old ford has a new issue, it has a knock on startup and goes away after about 5 minutes, what should i do.to.corrrct this?
Old Oct 1, 2013 | 12:43 PM
Bluegrass's Avatar
Depending on what causes the knock here is a list.
Piston slap that clears when heat expands the offending piston skirt to limit piston rock in it's bore.
Cam timing chains with worn tensioners and possibly low oil pressure.
Rod or main bearing.
You have to ID the source before knowing what to do about it.
Good luck.
Old Oct 2, 2013 | 02:02 PM
ishootstuff's Avatar
What oil and filter do you run?
Old Oct 2, 2013 | 06:55 PM
aussiekeeper's Avatar
Leave it running.......
Old Oct 2, 2013 | 08:39 PM
02FORD4X4's Avatar
Bluegrass: It clears up once the engine is warm and only does when the truck sits for 6 or more hours.
ishootstuff: Royal Purple 5w-20 with a KandN Gold oil filter
02FORD4X4's Avatar
Also it is so small you really have to listen to hear it.
Old Oct 2, 2013 | 08:45 PM
Well... I got nuthin' then. Right weight of oil and a silicone anti-drainback valve.
Old Oct 3, 2013 | 11:48 PM
papa tiger's Avatar
It may be an exhaust valve clearance.
Old Oct 4, 2013 | 09:26 AM
There is no clearance to set on hydraulic lash adjusters, but you may be on to something. Possibly a lash adjuster is failing or clogged.
Old Oct 4, 2013 | 10:21 PM
papa tiger's Avatar
Or worn camshaft.
