97 with 3in lift. 33x12.50 or 35x12.50
Old Sep 17, 2013 | 05:13 PM
Billim92's Avatar
I have a 3in body lift currently on my truck and it has some worn down 35s on it and was wondering if anyone might have a 97-03 with a 3in body lift and 33s that might be able to post a picture or someone with a 3in body lift and 35s that are new that I could refrence so I can decide what size tire I want to do. Maybe if anyone has an opinion on this that might want to pitch in.
Old Sep 17, 2013 | 06:25 PM
jbrew's Avatar
So..... Do you know if it has 4WD? That would help answer the question.
Old Sep 17, 2013 | 06:29 PM
Galaxy's Avatar
Search for my truck or look in my gallery. It's a 4" lift but close enough. IMHO, 33's are the only way to go. They just "fit" the body style.
Old Sep 18, 2013 | 12:44 PM
99Blue's Avatar
This is a 3" lift with 295/70R17. To me, this tire size is at the bottom end of acceptable as far as stance goes with this amount of lift. My earlier 315/75R16s (2nd pic) needed a chunk of the plastic valance taken out. The stock FX4 rims are 17x7.5 so they will be more tucked in than say a 17x9 with similar specs. Fender flares will also affect the overall look of your setup. I will definitely be going back with 315/70 or 315/75 once these wear out which won't be long.
To me, kingcrete's truck has the perfect stance for the 97-03 body. This is a 17x9 rim with 35/12.5 tires and I'm pretty sure it's a 3" BL.
Old Sep 18, 2013 | 02:59 PM
If you have 35's on it now, and they fit, why would you downsize? The cost difference is negligible, and well, bigger IS better.
Old Sep 23, 2013 | 07:50 AM
Billim92's Avatar
I think ill go with the 35s. I baught some 17x9 kmc rockstar rims so I think it will be a good combo and yes I too think bigger is better!
Old Sep 23, 2013 | 07:57 AM
pizzaman711's Avatar
You may need to crank your torsion bars some if you haven't already to help with the wider wheels depending on their offset/backspacing.
