Modifications
Old Jul 24, 2013 | 11:12 AM
pizzaman711's Avatar
If you can turn them yourself, it takes like thirty minutes, you'd be looking at around 75-85 for alignment and maybe 1800-2500 for wheels and tires depending on what you go with.
Old Jul 24, 2013 | 12:08 PM
Raptor05121's Avatar
4.2Ls aren't known for having a good exhaust note, just a FYI
Old Jul 24, 2013 | 01:10 PM
BurntOut's Avatar
I know raptor mine rumbles a bit but nothing like what i want plus its got an exhaust leak and im getting an estimate on that right now and ive got a shop to work in how hard is it to turn them
Old Jul 24, 2013 | 01:32 PM
It's basically turning a bolt. If you jack up the front end off the ground it'll make it easier. But you'll need to measure as you go because both sides will allow you to go up different amounts.
Old Jul 24, 2013 | 02:30 PM
BurntOut's Avatar
When i have it done i plan to run 20x9 wheels with 33s would that work or go smaller
Old Jul 24, 2013 | 02:31 PM
33's should be fine. What's the offset/backspacing on the wheel and how wide are the tires?
Old Aug 5, 2013 | 07:37 AM
yngbld3's Avatar
Go on Craigslist for wheels & tires...I got my rims for $400 & a set of bigger tires for $500 , & it sits a whole lot better..
Old Aug 5, 2013 | 07:39 AM
yngbld3's Avatar
Also bigger rim & bigger tire mean more $ , & weight meaning more fuel consumption..Hell I just got 182 mi out of a full tank...
Old Aug 5, 2013 | 11:37 AM
Tire plays more effect that wheel on gas mileage. And I'm guessing that's 182 miles without correcting the odometer..
Old Aug 5, 2013 | 12:52 PM
Without correctly the odo and with a gas tank from a Prius! I got 320 miles out of ~28 gallons every time before I corrected for bigger tires. ~11 mpg
