my odometer and trip meter doesnt work
Old Jun 10, 2013 | 02:40 PM
FACEtheZOMBIE23's Avatar
The meters are rolling but the speedometer works on my 97 f150 what is the cause of this??
Old Jun 12, 2013 | 02:02 AM
Meters aren't rolling I meant to say
Old Jun 17, 2013 | 12:33 PM
MitchF150's Avatar
VSS gear? But, if your speedo needle is working that would mean the VSS gear is okay?
Hummm... Since it's a 97, it's got the actual rotary (analog) odo/trip, but no actual 'cable' to the gauge like in the old days...
The VSS gear sends an electric signal to the computer which sends it to the cluster via the wire harnesses..
Not knowing which wire goes there, it's hard to say what it could be, but more than likely, it's something with the cluster itself...
Good luck!
Mitch
Old Jun 24, 2013 | 10:52 AM
Would it be easier to go to a junk yard and pull a new cluster off of another 97 and install it?
Old Jun 24, 2013 | 11:43 AM
knorverto's Avatar
But the odometer miles won't be the same
Old Jun 24, 2013 | 05:38 PM
cotedog03's Avatar
It is probably the worm gear, or the gears are just binded up. Mine did the same thing so I pulled out the dash and tore it apart. It becomes a pretty delicate process, my gears were all perfectly fine so i took the small motor out and spun it, and made sure the other gears moved freely. I assembled it all back together and once I put it back in it worked.
The worm gear though is the one attached to the motor powering the odometer, and is made of plastic. It is a common problem in all Ford's with the rolling odometers.
Here's instructions on it from an explorer, but it is basically the same:
http://m.odometergears.com/howto/FOR...EPLACEMENT.pdf
There's also a youtube video of a guy taking it apart from his ranger. He shows you how to get to the worm gear, but it is a tad different.
Old Jun 24, 2013 | 05:41 PM
cotedog03's Avatar
Also, Mitch is correct. If it was the VSS the speedometer would not be working as well.
Old Jul 1, 2013 | 10:11 AM
Awesome thanks I'll check it out. I noticed it didn't work after I reset my trip meter when I filled up. It rolled back to zero and then never turned I was like uhm what? Haha
Old Jul 2, 2013 | 11:43 AM
61 Sunliner's Avatar
I have a 98 with simular intermittent odometer issues. I can get the odometer rolling again by pushing the reset several times but figured it will soon fail completely. Was thinking of getting an ebay or junkyard speedo but wondered if they are linked to the vin# through the ecm or something.
Mike
Old Jul 4, 2013 | 04:29 PM
AlfredB18's Avatar
Mike
Not on a 98 model. You could just order the worm gear and swap that in and be done with it, though.
http://www.ebay.com/itm/94-99-Odomet...-/160949541756
34 sold? You are not alone, I reckon.
Old Jul 4, 2013 | 07:54 PM
Thanks for the link, funny Ford would go through the trouble to use a motor to turn a mechanical odometer gear.
Mike
Old Jul 5, 2013 | 05:43 AM
adrianspeeder's Avatar
Mike
After all the BS problems with the digital PSOM in the '92-'96 that you can't fix and lose your mileage, I'll take changing a lil plastic gear.
Adrianspeeder
Old Jul 10, 2013 | 12:18 PM
loboracer's Avatar
90mph, 1600 rpm and getting great mileage. ....
Old Jul 15, 2013 | 01:08 AM
AlfredB18's Avatar
I'd like them rear axle gears then. I think the last time I touched 90, my 4.2L was spinning about 2300 RPMs. :\
Old Jul 15, 2013 | 12:52 PM
That calculates out to 2.50 gears with 33 inch tires........
