QUICK question about rear blocks
Old May 25, 2013 | 12:49 AM
dabsevo's Avatar
Posted this on f150forum but might as well get input from here
I have a 99 f150 2wd on stock leaf springs. But it has bilstein 5100s in the front and rear. The front is raised I think something equivalent to a fabtech 7.5". The rear is stock (has the prerunner/Cali look). I want to raise the rear so I bought a 4" block kit.
Will 4" block set work with the bilstein 5100 shocks or will I need new shocks to use these blocks in the rear?? I dont want to start a project and have a truck that doesn't run because it turns out I need new shocks or something.
I did a search but it's hard to find specific info on 2wd, 97-03 and for bilstein REARS and 4" blocks. I have found that bilstein + 3" blocks have been run but nothing about 4".
This says 2-4" but it's for 4wd rear.. http://www.suspensionconnection.com/...tein-f150.html
Old May 25, 2013 | 01:59 AM
pizzaman711's Avatar
Rear shocks are the same for 4x2 and 4x4. You should be fine because the 5100's are only for lifted applications anyway.
Old May 25, 2013 | 02:18 AM
dabsevo's Avatar
Awesome thanks man. I was looking for a straight answer I hope it installs no problem tmw
Old May 26, 2013 | 01:52 AM
Buxton91's Avatar
Even it they aren't meant for the exact amount of lift you are putting on, it can't be any worse than running them with no lift!
