2001 f150 won't start (I know. Another one!)
Old Jan 3, 2013 | 01:38 PM
  #31
JCR 56's Avatar
You either have to drop the tank or take the bed off to change the pump.
Old Jan 3, 2013 | 02:13 PM
  #32
Bulldog24's Avatar
Read on another site that the supercrews have the pump under the cab, not the bed. I can't tell from looking, any idea? Also, is there a fuel pump control module that I should check first? Read that on another site also put can't find a part like that for my 02 online.
Old Jan 3, 2013 | 02:18 PM
  #33
jbrew's Avatar
Originally Posted by Bulldog24
Happened again this morning.
Old Jan 3, 2013 | 02:21 PM
  #34
jbrew's Avatar
Old Jan 3, 2013 | 02:26 PM
  #35
jbrew's Avatar
Old Jan 3, 2013 | 02:31 PM
  #36
jbrew's Avatar
Originally Posted by bulldog24
read on another site that the supercrews have the pump under the cab, not the bed.
also, is there a fuel pump control module that i should check first? Read that on another site also put can't find a part like that for my 02 online.
Old Jan 3, 2013 | 02:34 PM
  #37
jbrew's Avatar
I'll look,- IF your thinking about removing the bed.
Old Jan 3, 2013 | 02:38 PM
  #38
jbrew's Avatar
Old Jan 3, 2013 | 02:48 PM
  #39
jbrew's Avatar
No reply ?? To late now, I gotta go.
Good Luck
Old Jan 3, 2013 | 05:13 PM
  #40
Bulldog24's Avatar
Sorry, was out trying to figure out where it is. Was thinking dropping bed was best option since tank is full and I need this done now.
Is it my pc or are the replies above the last one from jbrew all empty?
Old Jan 3, 2013 | 06:09 PM
  #41
JCR 56's Avatar
Well, if the tank is under the cab of a supercrew, you'll probably have to drop the tank.
The fuel pump driver modules are on the 04's up.
Old Jan 3, 2013 | 06:26 PM
  #42
Bulldog24's Avatar
Now I'm really stumped. Got the p0302 and p0316 codes come back really quick. Could this all be related? Noticed a distinct sulfur smell while running.
Old Jan 3, 2013 | 06:31 PM
  #43
Toyz's Avatar
The sulfur smell is from a misfire/dumping raw fuel through the cats.
Old Jan 3, 2013 | 08:41 PM
  #44
Bulldog24's Avatar
I just find it a big coincidence that while I'm having the fuel pump issue I suddenly have a misfire in cylinder 2. Is it possible the lack of fuel pressure is causing the miss?
Old Jan 4, 2013 | 01:35 AM
  #45
Bulldog24's Avatar
Started with replacing the fuel filter tonight. Started up fine but it has been since I got stranded this morning. When I went to discharge the valve on the rail, I got nothing. There was also very little fuel in the lines connected to the filter. Not sure what that means but plan on running a pressure check tomorrow.
I also noticed a very large amount of water running out o f the exhaust at the muffler, enough to make a pool on the garage floor.
