2002 f150 engine issues
Old Oct 2, 2012 | 03:10 PM
p1808's Avatar
I have a 2002 f150 with 165000 miles on it. it has been having fit of rough running during acceleration and it sounds like a coil is misfiring. but all the coils where checked and the plugs and fuel filter changed. not sure if it can be a vacume line but i dont know how to test those. i was hoping that i would get a fault code but no luck as of yet and not sure what to do from her on out. i would like to take it to a shop but lack of funds prevents me from doing so.
would like to know if anyone has any other ideas.
thanks
Old Oct 2, 2012 | 03:11 PM
1997 lariat 4.6's Avatar
motor? What plugs did you use? Anything other than Autolite or Motorcraft will set these engines off...
Old Oct 2, 2012 | 03:17 PM
p1808's Avatar
sorry about that it is the 4.6 and the spark plugs are the factory replacements motorcraft pre gapped.
Old Oct 2, 2012 | 03:21 PM
jethat's Avatar
You woulld get a CEL if it was a vacuum issue that made it run rough. Sounds like a bad coil. The dealer could identify what one or you can just wait and eventually a CEL will trip.
Old Oct 2, 2012 | 03:24 PM
p1808's Avatar
do you know of any way to pull and test the coil packs t see i hey are workingroperly?
Old Oct 2, 2012 | 03:47 PM
jethat's Avatar
It sounds like there is an intermittent miss fire and the only way is a scanner that can load test the coils. Your choice is to take it to the dealer or order a complete set of coils off e-bay that you can get for less then the price of the dealer diagnostic. You should have coil on plug ignition not coil pack.. There are many seller take your pick. Search DG508 in parts and accessory. Here is a seller and I'm not reccomending them just showing pick one yourself.
http://www.ebay.com/itm/10-PCS-FORD-...sories&vxp=mtr
Old Oct 2, 2012 | 04:37 PM
p1808's Avatar
thanks for the info. i guess i know what i will be saving up for this month
