I've been told not to degrease my engine . Why
Old Jul 17, 2012 | 01:38 PM
  #31
jbrew's Avatar
Could just call them coils. - Can't go wrong
Old Jul 18, 2012 | 10:58 PM
  #32
4.6heavymods98's Avatar
So I got it done today and I tried a product called Gunk Heavy Duty Gel . What a waste of money I followed the directions to a T and it tuned out horrible! I couldn't believe it its like I didn't do anything at all! Here are the pictures after using Gunk.
It also left a white film on everything .
It did it over again after the engine cooled down with the super clean engine degreaser the stuff that come in purple bottle and of course came out more what I am used too. I did however use the Gunk engine shine and that did work much better than the other product. Here are the results of that .
Unfortunately I have a misfire on cylinders 2 and 4 not sure if its off the coils or the spark plugs can someone tell me which cylinders are 2 and 4 so I can just disconnect those two. The can be a bitch so I don't want to disconnect them all. I unplugged all the plug wires at the ignition coils since that's simple enough and I have a few fans running over the engine overnight.
Old Jul 19, 2012 | 12:33 AM
  #33
Toyz's Avatar
Standing in front of the truck...
4 8
3 7
2 6
1 5
Did you use compressed air to blow out the plug wells afterwards? If not, they are full of water. Pull the plug boots, blow the plug wells out, dry out the boots, apply dielectric grease to the boot ends and reinstall.
Did you cover up the coil packs?
Old Jul 19, 2012 | 12:59 AM
  #34
jbrew's Avatar
He has been told all that already. Well, he doesn't have a compressor. I know I said to cut up and old towel or something. Block off the plug chambers, to prevent them from filling up. He also was told to cover the packs. I believe others have tried to help to..
Didn't want you wasting your time as well.
Old Jul 19, 2012 | 01:10 AM
  #35
All cleared up and running like a champ again!
Old Jul 19, 2012 | 11:45 AM
  #36
pmason718's Avatar
I would love to do this on my truck but I'm scared of having issues afterwards. What do I need to cover up (pics would help).
Old Jul 19, 2012 | 12:34 PM
  #37
You have cops - you have to be even more careful.
Old Jul 19, 2012 | 01:41 PM
  #38
jbrew's Avatar
Old Jul 19, 2012 | 06:55 PM
  #39
@jbrew whats the problem got a little water on the plugs dried em out and its fine. Why is that funny????!
Old Jul 19, 2012 | 07:07 PM
  #40
jethat's Avatar
I think, When washing a mod motor or really ANY engine you have to be prepared to live with the consequences. You could get water in a plug hole and it could fry a coil. Worse then that could happen.. Gotta use common sense. Water gets in my distributor cap on my old mustang. Stuff happens. I like having a clean engine so once in awhile I roll the dice..
Old Jul 19, 2012 | 07:08 PM
  #41
@pmason718 That is one sick truck man!
Old Jul 19, 2012 | 09:37 PM
  #42
Bluegrass's Avatar
Apply a little common sense.
The coil voltage is as high as 40,000.
The boots dry out and can with help from moisture get pin holes punched through.
Water in that closed space turns to steam and become even more troublesome.
It's conductiive in that state and condenses on the surfaces after cool down.
If a motor is to be cleaned, remove the coils and put a 'cork' in each well to seal water out. Takes more work but a lot less hassle afterwards.
Good luck.
Old Jul 21, 2012 | 07:13 AM
  #43
At least you can pull the cap and dry it out.
Old Jul 23, 2012 | 11:17 AM
  #44
pmason718's Avatar
Thank you. I really need to upload some updated pics not that I have a bed cover, you just gave me an idea thank you
Old Jul 23, 2012 | 11:48 AM
  #45
czuber's Avatar
I guess I was lucky. Right after I got the truck from a mudding mad man. I took it to a car wash bay and sprayed it down with engine cleaner and power washed the whole bay. When I was done I hopped in and drove off, never had a issue.
