I've been told not to degrease my engine . Why
So recently I replaced a leaky valve cover gasket so I had a lot of oil in my engine compartment. I would like to decrease my engine but I've been told for some reason we can not degrease these engines but I have no idea why. I don't wanna use a pressure washer .Typically what I do is cover the alternator with a plastic bag then only when the engine is cool I spray degreasr in the engine compartment but sit for 10 minutes and spray it off with a garden hose. I also let very thoroughly dry sometimes as long as the weekend before I even start the engine.
Can anyone tell me why this would be a bad for a 4.6 liter triton? |
The cop's or coil packs are sensitive to water. You will more than likely end up chasing a misfire or a few misfires just shortly after washing it like that.
You can wash the front of the engine and the lower half of the side. Just keep the water off the top half of the engine. For the top half, I would recommend spending some time with degreaser and a rag. Soak the rag in degreaser and scrub away. Then wipe clean with a clean rag. |
You absolutely approach the job the right way...but there are reasons for not.
For one, the ominous sensors all over the engine compartment have connectors that may leak, allowing the corrosive degreaser in to cause an electrical failure. Over the course of 11 years of owning my F150, I have never had a big oil mess to clean under the hood but have detailed the bay with WD40 and, maybe a scrub brush, but also lots of clean shop towels. Safe method and used more than you would think. |
I did this many years ago, but I used degreaser and a pressure washer! :eek:
But I used them both "wisely".. ;) Before: https://www.f150online.com/forums/me...trip-idaho.jpg I sprayed the degreaser on only the lower part of the engine and where the 'grease' actually was and no wires. When you use a pressure washer, if you keep the tip about 18" away from what you are pointing at, all it is is a mist... A lot less volume of water than what comes out of a garden hose.... :smoke: You also have the instant 'on/off' with the trigger. All the while, still only using a fraction of the volume of water a hose with a spray head would use. Basically, you keep all water off the top of the engine and only spray on the sides and front and DON'T spray on any wire harnesses or essentially ANY electric part... I started my engine while the thing was still dripping. Closed the hood and made sure it was not 'missing' or sounding funny and then took it for a 15 minute drive. When I got home it was completely dry and after it cooled down, I sprayed some 'tire dressing' on it and wiped it all down to get this: https://www.f150online.com/forums/me...ned-up-now.jpg You can spray in other areas without worry too, but you do need to pay attention to what you are doing and don't just 'drown' the thing... ;) This is just what worked for me and I had a clean engine compartment and no ill effects... I'm sure there are a zillion other ways to do it and other methods that work equally well.. The main point is you just have to know what you can get wet and what you can't... :) Good luck! Mitch |
I clean my engine once a year or so. I always stay away from the center but if it gets really dirty I'm cleaning it. I'll deal with the issues. Always blow it off with compressor air..
Originally Posted by jethat
(Post 4868267)
My engine ALWAYS looks like this. If it doesn't look like this, I fix it with no regards to how long ago it was I washed it. So far (knock on wood), 10 years and and 135,000 miles with zero issues I'd relate to washing my engine! http://img193.imageshack.us/img193/693/img2149z.jpg http://img94.imageshack.us/img94/7676/img2148u.jpg |
Originally Posted by Galaxy
(Post 4868311)
Bingo! I'm probably a once every 3 months or so guy. Degrease and rinse off. Then dry very well, especially around electronics. I do not attempt to avoid electrical connections and stuff. The only two areas I really avoid are the alternator and the air filter; usually cover both of these with a plastic bag before I start.
I can't believe you let your engine get that dirty... how embarrassing.
I'm around too much dust to be able to keep mine that clean. Not that it is dirty, just not as clean as that. I have always wiped mine down by hand and with a spray bottle. No grease issues though. Just dust. Oh, and your missing your electrical cover on the passenger firewall |
Originally Posted by Toyz
(Post 4868317)
1 Attachment(s)
(Post 4868362)
Was that for me?? If so…????????
The dirty engine part was sarcasm This cover here... Attachment 23545 This is what mine typically looks like... not the cleanest but not horrible to look at. This what right after the swap. It's been cleaned a few times since then |
Dude, that's not bad at all. Looks just fine. Mine never had a cover on it like that; bought it brand new too. I'd like to have one though, except I'd have to remove it all the time to clean behind it anyways, LOL!
Yeah some trucks didn't come with the cover, like mine :(
I don't have one either.
When I bought mine from a new car dealer, they of course detail the engine since it was used, and I had misfires on different cylinders. Mostly on the #1 cylinder.
How many miles? Misfires are more of a spark plug thing. Wet COPs would be more of a rough idle.
I pressure wash mine every once and a while. I wrap an old shirt around the air filter and then a short over the coil pack. Everything else I go to town on. |
| All times are GMT -4. The time now is 04:44 PM. |
