A few 99 F-150 XL questions
Well, best thing is to blast it then. No blaster ? - You can wire wheel the snot out of it and apply THIS stuff only, for the best results.
This first - http://www.ebay.com/itm/POR-15-Prep-...item5198dc274c
Then this - http://www.ebay.com/itm/Bill-Hirsch-...item3f132f63fa
Then head up to Sherwin Williams and have them whip up your paint code in a couple aerosol cans for yuh..
It's the best you can do other than welding in new metal. - Or replacing the doors.
geez you guys know your stuff!
The code is indeed a HEC code from the dash and is implicating the oil pressure switch.
The engine PCM diagnostics does not look at that switch.
You should see a malfunction with the dash gage operation.
Good luck.
Good luck.
