does the P1000 drive cycle reset need to be in order?
Old Mar 13, 2012 | 12:54 AM
jgger's Avatar
Thanks!
So could this be his issue?
Old Mar 13, 2012 | 01:02 AM
Bluegrass's Avatar
I can't tell from here!
He has to look.
Old Mar 13, 2012 | 01:09 AM
jgger's Avatar
Gotcha. Thanks Bluegrass
Old Mar 13, 2012 | 01:43 AM
jbrew's Avatar
Yea but, if that were the case, you couldn't pull any info from the KAM. It would be dead memory until reactivated. It wouldn't reactivate without that fuse to complete the circuit. Right ?
Hell Iduno, I better check my fuse
Old Mar 13, 2012 | 08:03 AM
projectSHO89's Avatar
No, if the KAM fuse circuit was open, it would just behave the same as if the battery were disconnected - every time the truck is turned off.
All tables and stored monitor information would be reset to defaults and the monitor cycle would start all over again.
Old Mar 13, 2012 | 02:23 PM
jbrew's Avatar
Yea, I knew I should have put more thought into that. :o
Old Mar 13, 2012 | 04:54 PM
jethat's Avatar
If the KAM is reset the gauges sweep on start up. Thats what he should look for. Then he knows its a bad fuse or some other connection issue.
Old Mar 13, 2012 | 08:23 PM
jgger's Avatar
Bottom line, it would give a P1000 at every start up. Right?
I'm trying to learn here, if I'm guessing wrong just tell me to shaddup.
Old Mar 14, 2012 | 07:27 AM
If the power feed for the KAM were missing, then, yes, it would.
Interesting. I've not previously observed that nor have I heard of that behavior. I'll have to look at my 01 SD to see if behaves that way.
Old Mar 14, 2012 | 07:38 AM
MGDfan's Avatar
I suppose you could use these Mode 1 PID's to check, if supported ... just a thought
Mode / PID / Data / Description / Min / Max / Units / formula
01 / 4E / 2 / Time since codes cleared / 0 / 65,535 / minutes (A*256)+B
01 / 30 / 1 / # of warm-ups since codes cleared / 0 / 255 / N/A A
01 / 31 / 2 / Distance traveled since codes cleared / 0/ 65,535 / km (A*256)+B
MGD
Old Mar 14, 2012 | 11:21 PM
rcantu's Avatar
wow. i didn't get any more updates to this thread. It's been 80 miles so far and the p1000 is still there. I have a scanguage 2 and read up that I can send hex code to get a code back that I would dicipher. http://www.scangauge.com/tips-and-tr...-scangauge-ii/
So i went ahead and did that and got a result.
It appears to be the EVAP because the "q" value was "4"
so i'm reading this drive cycle info here http://www.obdii.com/drivecycleford.html
do I need to try to follow steps 2-14 as stated? It says i can only do this within the first 30 minutes.
Old Mar 15, 2012 | 01:20 PM
You may have an issue with something in the evap system.
Did you CHECK the KAM fuse?
Old Mar 15, 2012 | 09:06 PM
jbrew's Avatar
Yea, he isn't listening to anything, - what's the use
Old Mar 15, 2012 | 09:15 PM
rcantu's Avatar
Please elaborate what am I not listening to?
the fuse is fine. I do not have any sweeping gauges.
I also posted that the scangauge2 I had happened to be able to run a command to pull a code to confirm which tests haven't passed and it appears to be pointing to the EVAP.
I asked if I had to do the entire drive cycle or is there a short cut.
Again if I'm ignorant, deaf or stupid I'd like to know so I can correct it.
Thank you
Old Mar 15, 2012 | 09:38 PM
Not to butt in, but been alot of unhelpful attitudes around here lately. Getting old.
